79 frame compatability
Finger Lakes region ny
I have a Sept. 79 build date fj40 and am in need of a donor frame. The one I have has major rust issues. Would like to know what frame years are compatible with my fj40. I don't mind doing some mods to make it work.
Thanks for any help.
79+ if your fuel tank is below floor
73ish-79 if fuel tank above floor under seat
73-84 with some work for the wrong one
Any year - more work
I have a 78 as well so I'll inspect the mounts and location in comparison to my 79. My body brackets on my old frame are usable maybe I could mock them up to a +-78 frame if I can't find a 79 + frame. Thanks for all the help
it really depends on what month the 79 was made. if it was Dec 78 or earlier the 78 frame is correct. if it is Jan 79 and up you need the later frame. the big changes started in Jan 1979 with the gas tank under the body and square headlight bezel among other things.
just re-read the first post and it states Sept 1979 build, you need the 1979-1980 frame
I've got an 82 frame but as stated, the body will bolt on to the frame it's some of the other things that don't cross over.
Does the 82 frame have a title?
I'm really in the market for a 79-80 frame to do it right and save the headaches. If it comes down to I'll get a new one from Aquila, but I would rather have a donor
81+ is not that hard to adapt compared to pre 79. Use the rear motor mounts from your current frame and find bushings that will allow you to use your springs or if your springs are old and worn just replace with the 81+ 40 series springs.
