79 FJ40 emission help---again?
An old problem that I never got around to fixing -- had some advice from this board about 2 years ago but 'lost' the printout...anyway, here goes (again):
79FJ40 stock - with all emissions lines, smog pump, etc. intact -- carb is stock and rebuilt. Manual choke. The issue -- truck starts just fine with only the least bit of choke pulled out. Within a few seconds I can push the choke back in and she idles very nicely. Once the engine gets up to operating temp (depends on outside temp --lately that isn't too long) the engine begins to run rough and will not idle without the choke being pulled out about 1/3 to 1/4th. Yeah, it starts to sound like a vacuum leak or manifold (intake) leak but this is where things get interesting. Once the truck gets really warmed up (still only 1/4 on the temp guage thanks to a new water pump and radiator) and driven for a few miles (in hot weather it takes less time) - the engine will suddenly surge with RPMs going up quickly -- that's the signal I can release the choke all the way back in. Engine then idles once again great without any choke. Go figure -- is this telling me one of those darn VSVs are not opening and closing as designed? Any suggestions - gas mileage is bad enough but having to drive around with the choke out for several miles doesn't help.
Have been absent from the board lately -- got the crazy idea to take up flying lessons -- that has occupied my time and money the last year or so.
Thanks in advance
Tom
You could multiple problems but won't know until you start checking. Here are sevearl ideas that come mind that could cause this. The egr may not be closing during idle like it should. Try taping it see if you can make it go away if try test as per the toyota manual. I replaced mine with the newer style (reamed the hole bigger to make it fit). Spray carb cleaner at the base of intake and exhaust. What makes it interesting is that the problem intermettently comes and goes.
Don't remember if the base of the carb is where the egr goes. I think it does on a 79. If it does make sure this pholnic plate is not inverted causing it to block the egr circuit. The carb could still be an issue. Check if the shut off soleniod working like it should. also make sure the O ring is intact and funtional. Good luck.
The EGR outlet moved to the intake manifold in '79 and if it sticks open, it can cause the type of idle problems you describe. Pull a vacuum on it until it begins to stumble and then release the vacuum to see if it closes and idles nicely. If not, it needs cleaning. You can lube the operating rod with graphite.
It could be some other temperature sensitive vacuum leak as well, so if it isn't the egr, do the usual leak test by spraying carb cleaner or propane gas around the potential leak points and see if the rpms jump up.
Thanks guys -- I historically had an intake leak but after several attempts I finally solved that by taking the entire intake/exhaust assembly and had them machined and a new gasket installed. No leaks now -- can spray the carb cleaner and no increase in RPM. I'll check the egr, etc. -- thanks. Tom
