Wanted 79-84 40 parking brake handle/bracket
cruisermatt
Un-manufacturable
Supporting Vendor
Winter Park, Florida
Website
www.cruisermatts.com
Looking for late model parking brake handle and floor bracket that cable attaches to. I’m showing two versions of the floor bracket 79-82 and 82-84 so hopefully someone can chime in with that info. I know there is a difference with the cables that follows those years but not sure what the difference is there either.
It’s a retrofit either way so might not matter.
Matt, something like this? No bucket or cover.
Yes, however that might be a 60 bracket? The mounting hole pattern is about 1” smaller on the 40’s.
Here you go, Matt
Thanks Amir, can you Pm a price for one with a bracket please? I’m good on covers, I have new 70 series vinyl covers.
Do you know the difference between the pre/post 82 handles?
I have a couple in Burbank, both 40 series.
do they have the bracket that the cable clips to as well? Waiting to hear back from JB and Amir as order of received.
There are two handles here. Foreground handle is a 1982 FJ40 (3/82 mfg date). Background handle is a1980 FJ40 (11/79 mfg date). There is a slight difference in the length of the catch pawl and the teeth pattern. I do not see any other differences in the handles. Bucket looks the same on both. Of course downstream from the bucket you have major differences in the parking brake setup.
There are two handles here. Foreground handle is a 1982 FJ40 (3/82 mfg date). Background handle is a1980 FJ40 (11/79 mfg date). There is a slight difference in the length of the catch pawl and the teeth pattern. I do not see any other differences in the handles. Bucket looks the same on both. Of course downstream from the bucket you have major differences in the parking brake setup. View attachment 3256658
Thank you for this! I have not been able to find this info anywhere.
I have an 83 project here that is missing the handle. Here’s its bolt pattern. Roughly, from IPhone camera measurements.
I have a friend with a 82 RHD HJ47 and he measurements his at 2.5x4.25” roughly…
This here looks like it will match up a lot more with a 60 handle then a 40 handle?
@gtscotty would you be able to compare your handles’ mounting pattern?
Ok some more pics. There is a slight variance between the 1982 (beige) and the 1980 hole measurements. The most critical measurement is the 6 inch diagonal (opposite of what you have in your picture) as those are the two mounting points of the handle. My 1980 handle is 6 inches across that diagonal. In reality there is plenty of play in the whole thing. Just don’t weld up anything until you have the handle you are going to use. Also note the support plate on the underside.
Looks like @FJ40GURU has me covered
Well I got my 40 handle in... it ended up being 1" or so too short for this 83 FJ45 but a handle and bracket from a 60 worked out perfectly.
