78 2f
Sedro Woolley, Wa.
Help - I have a 78 non USA 2F on the floor while doing a frame off on a 45. It has been setting for some time so thought I would do a valve and ring job. The cyllinders have hardly any wear. I don't have a real Toy manual(lost in the move) so checked a Han*(^% manual for specs and it lists a 2F cyl bore as 3:70. Mine is 3:52 on the ridge and 3:56 under the ridge. Excellant right? The manual shows this as specs for an F motor. The 2F should be 3:70". Now I am wondering is this a 2F head on an F engine? But the engine number is 2F872158. What are the Toyota manual specs? Thanks for any help. Bill
2F Standard Bore 3.7008 - 3.7027 in
Wear limit 0.008 in
F Standard Bore 3.5431 - 3.5450 in
Wear limit 0.008 in
Gotta wonder what is up.
Thanks. I was sure I remembered 3:70" for the bore and It was a Shock to see 3:52' on the mic. and 2F in the engine number. I will take my mic to a machine shop and have it checked. Spooky that it is so close to what an F bore. is.
This whole truck has been weird. Full floating axels with positraction, drums up front. What next?
Could be due to non-USA. Perhaps they built non-USA 2F engines with different specs to allow for lower grades of fuel? Or, perhaps this is a transition engine built with a left-over F block but tagged as a 2F? Gotta wonder if the oil system is like an F or a 2F.
I thought SOR had a serial number index for engines, but I could not find it a minute ago.
its probably like the 74 f ...has the oil sys of the 2f but the bore of an f engine...since you said it were a nonusa 2f i would say they were still using the block design from 74 tru out in other parts of the world ...maybe...
does sound like a 74 f engine though...
does it have a 2f type oil sys?
Per Poser's 2F serial number thread, that number corresponds to an engine from a mid-80s 60 series. Not sure of the exact vintage, but newer than '84. Is it possible that the engine is sleeved?
All late model 45's came with drums in the front. All the ones that came to canada anyway.What kind of positraction is it?
OK I gave the wrong engine ID. The number is 2F 237080 which according to Specter's chart is a 78. The side cover is not dented for the larger distributor but it does have holes for a power steering pump. I had my micrometer calibrated at a machine shop with a 3"to4" Starrett micro and it was less than .001 off. I got him to set mine on 3:70. Checked the cyl and it likes almost 1/8 of an inch of going in. WTF do I have here?
I'd say the above answer about it being similar to the US '74 engines is correct. Might be that bore and stroke were not the Toyota reason for naming a new engine series and it's only coincidental that they also upped the power for US models. We're the horsepower happy people, and Toyota has always seemed to cater to their perception of each market.
When dealing with non US cruiser stuff there's lots of surprises if you go in expecting everything to be as it is in US market stuff. Some's the same, some's not.
Is it hard to find rings and bearings for 'F' engines? Someone told me it is.
kbill,
We need pics of the engine block. It's either an F engine that some lowlife has stamped a "2" on the serial pad, or else it is a 2F that had bore problems, so someone sleeved it down to F bore.
A pic of the serial pad
or the block part number (something like 11411-61013)
or show us the date code as seen here:
pic
Thanks Jim. I will look today. Will also pull one piston and see if it has 2 oil rings. I don't know how to post a picture but trying to learn. Bill
The block number being a 61011 makes it a 77-78 2F, vs a F block w/ a 600xx number.
Date code is 1978 Jan 23rd.
Apparently it's a 2F that someone sleeved down to accept a cheaper 3.5" bore chevy 235 piston.
Thanks Jim. It has to be something like that. What would you do? Right now I am thinking recycle although it has hardly any ridge. Couldn't find my engine stand adapter so unable to remove a piston.
When you get it on a stand, finish tearing it down to see what might be salvageable.
Engine may be built out of junk.
What is the casting number on the head?
Something like 61030 would be appropriate.
