77 Rear Tail Light Guard Hardware
Carlstadt New Jersey
Would anyone happen to know if the hardware is still available from Toyota or another vender. These are the 8x1.25 20mm long self tapping bolts with capture washer/lock washers. The head is marked with the #4.
Thanks
Dave
I’d check with your local Toyota dealer. Mine will tell me if the oem part is available or not and even print me out am IPB. You would be surprised at the parts (especially nuts and bolts) still available. If they are not available I hear McMaster Carr is a good place for bolts.
Just in case you were not aware, a good resource for tracking down OEM part numbers and part availability is Here. Then, using the online microfiche, you can see the exploded parts diagrams for your model year. Once you are armed with the part number, you can plug that into your dealer's parts department's website.
Thanks
Dave
Per the EPIC, the bolt part number is 91611-40816.
