For Sale 76 rolling chassis, Metaltech, SOA
Dallas
Website
www.octagonmma.com
Spring over axles plus disk brakes w/o locked diffs...$1k ea
MT full fam cage plus all extras in plastic still and unassembled, MT floor plates, corner bars, hip bars, spreaders, dash bar, grabs, belt bar, only missing the seat cradle bars... $750
HFS 2.5" lift springs $900
Straight no rust frame coated with 1 step to protect and awesome tub w/title and data plates....$2000
F & R ambulance doors, 100% complete but bottom typical rust $300/ea
windshield frame and new glass $200
Corbeau top of the line memory foam susp seats SOLD
Entire rolling chassis $5500 w/springs, front shackle reversal pro welded with custom hangers and SOA, 4x4 Labs hi steer, discs up front, Saginaw ps, 4x4 Labs Sagniaw kit plated up front by pro welder, 4 wheel brake disc kit with two Summit prop valves, steel lines, Toy/Chevy calipers front/rear, discs up front and rear caliper adapters. 18" steelies and spacers. All hardware from Downey and RuffStuff. RuffStuff longtravel front hoop kit and all hardware plus 5 point belt cage tie ins.
Fiberglass cap for hardtop-$275
1994 Short block Chevy 5.7L no intake/accessories plus Downey adapter mated to stock 4spd -$300
Extra set of 285/70/18 KM2 Mud Terrains 75-80% tread. $700
I basically have everything minus an LS and tranny to drop in..... bolt it all together and go.
Life has prevented me from finishing.....ping me for details. All original bolt set, bits/bobs and thrown in.
http://s53.photobucket.com/user/alexeinspruch/slideshow/For Sale
MT full fam cage plus all extras unassembled $700
Straight no rust frame and tub w title....$2000
F&R Doors, complete but bottom typical rust $300/ea
Corbeau top of the line memory foam susp Seats $350/ea
Entire rolling chassis $7000 w springs
Power steering, linkage and 4x4 Labs 1 ton TREs $400
Free good short block Chevy 5.7L no intake/accessories plus Advance Adapters mated to stock 4spd
18" steelies and a set of 34.9" KM2 Mud Terrains 75% tread. $400
I have everything minus an LS to bolt it all together but life has prevented me from finishing.....ping me for details.
Please send pics of the axle and tub to jonthamilton@hotmail.com, wonder how much difference between 78 and 77? Avy idea how easy it would be to merge the two?
Emailed ya bud.
Straight no rust frame and awesome tub w title....$2000
Entire rolling chassis $5000 w springs, SOA, 4x4 Labs hi steer, discs up front, Saginaw ps, plated up front by pro welder 4x4 Labs sag kit, brake disc kit with two Summit prop valves, steel lines, calipers front/rear, discs up front and rear caliper adapters. 18" steelies and spacers.
Short block Chevy 5.7L no intake/accessories plus Advance Adapters mated to stock 4spd -$300
Life has prevented me from finishing.....ping me for details. All original bolts and bits thrown in.
Interested in the KM2s and metal tech cage. Can you give me the details on what is all included with the cage? How many tires are in the set and can you send me pics of the tires? Any plugs, patches, sidewall issues? jgrande428 at gmail dot com
Still nada?
Needs to go. Drop an engine in and WHEEL!
PM sent
TTT
Hey just now seeing this. 5.7L 350 TBI 94 ran like a champ. ECM, harness and throttle body stolen along with the alternator.
I'm actually looking for a way to overhaul the TBI manifold, add another throttlebody or replace engine! Seems equal in cost for a pulled complete 5.3 vortec.
Wow, stolen? How did that happen?
How many miles on the engine? Any damage to it since the 'thievery'? Any way to get the package to Denver?
It was under tall fence with barbed wire locked up at a shop who turned a blind eye.
Intake manifold got a bit flash rusty inside where throttle body sat - probably could be dipped and blasted. Block is still solid as this sucker came all the way from CA without issue to be pulled (and replaced by a 6.0L) from a 60 series. Engine is a '94. I'd use the block but new pulled engine costs same as new TBI, DME, harness, etc....
Come and get it.
BUMP
Replied and a BUMP!
