76 2F dies randomly.
Utah
THis started about a week ago.
During periods of extended higher speed driving, my FJ40 will simply die.
I Was on the freeway this evening, and the truck just died. No warning. Nothing.
The only way to get the truck running again is to turn the ignition off, then turn it back on, and the truck will fire right up.
I have noticed that the truck has been pinging more at higher speed, and under load. So I have been running mid grade fuel.
Timing is set about 12dbtdc, which is the sweet spot for my altitude (this is where I always keep it). But it's been pinging more often.
I am running a non-usa toyota distributor, with points and condensor. A stock ignition coil. I removed the ignitor a few months ago, because it was going on the fritz. I also bypassed the stock ballast resistor, as the truck will not run with the ballast resistor in place.
Points look good (not burned). Points gap is where it is supposed to be.
Any ideas?
Thanks!
I tested the coil this evening.
Getting and orangeish-blue (or is it blueish orange?) spark from the coil.
Hooked my multimeter up
Primary winding of the coil show 2.5 ohms on the '200' setting of the multimeter
Secondary winding shows 27.6 ohms on the '200k' setting of the multimeter.
HTH
The '76 also uses an ignitor, combinded with points. THere is a trail fix described in the owners manual and in the FSM to bypass the ignitor and run a conventional ignition. I would do that and see if it works. The '76 ignitor is hediously expensive if that is the problem.
Check all the basic stuff too, like condition of wiring, fusable link, battery connections, fuses etc. Actually, I would change the fuse and clean up the socket where it fits.
In the past, ignitors either work or are dead, but at a minimum I would clean the connections and check it all out. Do you have another coil/ignitor you could swap in and test?
One last problem that I had on my 76, is the bushings of the distributor wear out and the shaft wobbles enough to way change the dwell and make it run poorly. You can buy rebuilt ones or send yours to Jim C who rebuilds the distributor with new bushings.
I would suspect an intermittent problem with the ignition circuit somewhere between the key and the ignitor; either a bad connection or a short. This circuit is not fused.
It if dies regularly enough, you could try bypassing the ignition circuit for test purposes by removing the black/yellow ignition power wire and hot wiring it from the battery to the ballast resistor. If the problem persists, it is not in the power feed, but down stream at the ignitor/coil/distributor.
PS. Pinging isn't good. It is telling you that the ignition is too far advanced.
The ignitor and ballast resistor has been out of the loop for 2 months now.
I am running a standard ignition, minus the ballast resistor.
Also about the pinging, the timing hasn't been advanced AT ALL.
Could improper Dwell cause pinging?
A side note
What is the possibility of it being the voltage regulator causing the problem???
If you have a coil that uses a ballast resistor, you need to use it or the coil may overheat and fail.
Dwell has a direct effect on timing. As the gap decreases, the timing retards.
Any ideas?
Thanks!
ignition coil, had the same problem. The cruiser would quit intermittantly then start back up. The fact that the coil will not work with the ballast resistor in place indicates the coil is failing. As the coil heats up and breaks down. Put another coil on and try it, just get a cheap 12v coil for the test. The ballast resistor/coil combo was originally intended to provide a strong spark to ignite a rich fuel/air mixture, when the starter is disengaged the coil goes to 6v operation. When you bypassed the ballast resistor, you began running the coil at 12v continuously, which it was not designed for.
Try a new coil!
eric:beer:
You might also try installing a Pertronix system and getting away from the points. I agree with the others, though...you need a ballast resistor.
