'74 Running Rough & Low Vacuum
Beaverton, Oregon
I started typing this into this thread, since I've got pretty much the same issues with my '74, but I got too long-winded and just started a new thread.
Quick background. 1974 FJ40. All stock, but partially desmogged by the PO. I got it running a few weeks ago for the first time in 25 years, but had a wicked exhaust leak from the busted up headers. Put a set of Downey/Mark's headers on with a Remflex gasket and had the intake planed flat to the same thickness.
Upon install, two things happened:
  1. I used too small of a washer on one of the manifold studs and it got sucked into the gap, breaking off the last tiny little bit of one of the bottom-center tabs on the intake manifold. It still had about 3/4 of the tab left, so I decided to run it. With a better washer, it mated up and sealed down just fine. I think.
  2. One of the carb stud holes looked buggered up. It seemed like it would still tighten down, so I put it back in and bolted everything down. When I tightened the carb down, the stripped stud was pulling out as I cranked it tight. It never got tight, just started pulling out. I left it tight enough, which was apparently not tight enough.
New 2.5" exhaust was put in at the local exhaust shop. Magnaflow muffler tucked up out of the way. Looks and sounds great.
Since getting it all running, I'm struggling with low vacuum, which I can't find the source of, as well as some pretty serious hesitation, bucking, and backfiring above about 1500 RPM. I have adjusted the valves three times and think I have them dialed in pretty well. Vacuum was just barely 15", I have it timed right at the bead (7° BTDC), and I have the idle mixture set to just where it plateaus around 15", then cranked back to lean it out a bit.
It idled pretty good at 650ish RPM and sounded smooth idling. Off the line is fine, but it starts to feel like it's leaning out about 2/3 the way toward needing to shift. It gets worse as it warms up.
As it warms up, it increasingly wants to backfire and cut out, as well as crackle and pop out of the exhaust as it decelerates or coasts in gear.
I can sort of power through it by keeping the revs up a little, but there is no accelerating after about 1500 RPM—just a steady, sputtering pull. No feeling of the secondary opening, no extra oomph. Nothing.
Digging back into it, three of the carb mounting nuts were loose. Thought this was the vacuum leak. I drilled it out the bad threads and put a Heli-Coil in, but when I reinstalled the stud, it started to pull the Heli-Coil out and was bulging the aluminum around the stud. I stopped. It was mostly tight, though maybe not quite as tight as the others. New carb base gasket above the spacer, and it seemed to bolt down better. Upon reinstalling and readjusting the idle mixture, the vacuum came up to 16-17", but driving it was the same. Maybe a touch better, but still rough above idle.
Driving it yesterday after warming it up, it started running like crap and was wanting to die. I had to pull the choke to keep the revs up just to make it home. Popped the hood and realized that the vacuum cap on the booster (recently rebuilt by Booster Dewey) had popped off, along with the PCV hose having detached from the valve. Plugged the PCV hose in and put the vacuum gauge on the vacuum port and it runs as before. Idles great. Pulls away from the line smoothly, then hesitates.
I can't find any other vacuum leaks. Spraying carb cleaner and water around everything I can think of causes no change. I'm leaning now toward rebuilding the carb, as it clearly needs it. It sat with fuel in it for 25 years in a cold, damp barn. The gas tank was shot. All the rubber lines were replaced, it has a new OEM tank, a clear filter with no specs of contamination, and all the hard lines were cleaned out and look fine.
The PO mostly de-smogged the motor. The retard port on the stock distributor is capped and the threaded port on the manifold is capped off. The only vacuum lines off the carb are the DS base of the carb into the computer, and the diaphragm on the DS top of the carb, also connected to the emissions computer.
I was leaning toward a new advance distributor and having the carb ported and rebuilt, but then read that JimC recommended not going that route if the de-smog was only partially complete. Hoping to get a consensus of where to go next. I'm guessing that the carb is leaning out above idle due to some crud inside the carb, but this doesn't address the vacuum issue. Could there be an air leak inside the carb causing the low vacuum?
I'm fine rebuilding the carb on my own, but don't feel comfortable eyeballing the drilling of the vacuum port on a perfectly good Aisin carb. Seems like I should be able to get this setup running better than this without changing distributors.
Sounds like your carb is going to get a thorough cleaning.
In the secondary bore is a high speed valve. The HSV shaft has a counterweight. Does it seem bound up?
You could bend the primary to secondary linkage, so the secondary opens up sooner. Before bending trace the linkage or borrow some play-doh to get an imprint:hillbilly:
21411
Good call. The HSV was all gummed up when I took the carb off to fix the stud. I sprayed carb cleaner on it and loosened it up a bit, but it probably still isn't moving freely enough. I know the carb needs to be gone through. Really just trying to decide if I should rebuild it myself for the old retard distributor, or if I should have it ported and swap the distributor.
Timing is pretty steady and the shaft seems tight. I'm leaning toward just rebuilding it on the cheap and addressing other areas of concern. I've got lots of other things to attend to before I really start driving it much anyway.
Update:
Rebuilt the carb using the Keyster kit from @cruiseroutfit. All seemed to go well. After mounting, it started right up, idled just ok, so I drove it around the block to warm it up so I could adjust everything properly. Ran fine with the choke out, but got progressively worse as I drove it and it warmed up. Once warm, I tried to push the choke all the way in and it died. I had to keep the RPM up to keep it from dying. Pulled it into the garage, tried to adjust the idle mixture, but it wouldn't run without the choke and a high idle. After killing it the last time, it would start up, rev high with the gas pedal pushed in, then die slowly. It was like the engine would burn the fuel I pumped in with the accelerator pump, but nothing else was getting through. Fuel bowl was perfectly half-full, so I unplugged the idle cutoff solenoid... no change. Plugged it back in and no click, despite 12V to the solenoid.
I just pulled the solenoid and realized it was gummed up and the rod was bent a little. I pulled it apart and cleaned/straightened everything, and it now clicks properly and seems to be working. The battery is dead from me leaving the key in the ACC position all night after trying to start it for 20 minutes yesterday. Stupid. Charging now. Update II in a bit. Fingers crossed.
Random thought, If the ICS keeps acting up you might try adding a direct ground from the firewall.
Also doesn’t take much to plug the idle jet even on a freshly rebuilt carb.
Update II:
No dice. Well, sort of. Progress on some fronts, but still the rough running under load remains.
Post carb rebuild and adjustment, the truck idled smoother, but still ran rough, then wouldn't idle (see above).
I rebuilt the ICS and straightened out the rod and then noticed that the 12V I previously had to the solenoid was no longer working. At least now, I can install a jumper to the solenoid and it works properly with 12V from the battery and started right up. Test drive went fine while choke was on. Idle was the best it's been and it ran great until it warmed up and I pushed the choke all the way in, then it was back to the same old rough running—cutting out/backfiring, sputtering, loss of power, etc.
Back to the garage to readjust the idle mixture with the truck warm. Idled even better, but no change off idle. I started thinking it was odd that it was worse when warm, so decided to check the valves again. Loosened them all up and checked them. One intake valve was way too tight when hot. I finished the valve adjustment, then went to readjust the carb and noticed that the vacuum was up from 15" to a shade over 18", so that was good. I excitedly headed out with good valves, a properly adjusted idle mixture, and timing set just a shade past the BB (~9° BTDC?). Idle was the best so far, valves were a little louder, but the idle was more even at the exhaust than it has been. Great off the line with a little choke, got it all the way warmed up, pushed in the choke and... same. The only improvement is the crackling and popping out the exhaust was better. Still ran rough, still backfiring out the carb. Still seems like it's leaning out too much off idle. Pulling the choke a little makes it run substantially better, albeit at a much higher idle speed. Really seems like it's just too lean.
I sprayed water everywhere I could reach and couldn't notice any vacuum leaks. Maybe the slightest dip in RPM when sprayed under the manifolds near the spot where I broke a 1/4" of the tab off the intake manifold, but then couldn't replicate it. Now that everything is adjusted properly, I can't notice anything. New base gaskets on the carb spacer. Everything is tight and seems fine and vacuum is now steady and higher than I've ever seen it on this motor.
I'm stumped. My only thoughts now are that the carb might be jetted too lean. I installed the standard 120 1° main jet and the 180 2° main jet with the rebuild. The only weird part of the rebuild was that the Keyster kit had power valve jets marked 55 and 60. The power valve jet that was in the carb was marked 80 (spare high-alt PV jet in the main jet plug was a 55), so I just reused the 80 jet with the new power valve. I'm wondering if the 120/180 jets from 1974 are just not right for today's ethanol crap gas. I live about 300' above sea level and most of my use will be below 6,000', so I may explore some larger jets. Any suggestions? I'm running out of ideas.
Oh, to be clear, I haven't yet tested the fuel pump, but I was able to get it to backfire in the garage and the bowl stays right at half-full no matter what. New fuel tank, new rubber lines, all hard lines cleaned out, clear filter shows no contamination.
Also, the Keyster accelerator pump piston from the kit was way too tight, so I re-used the leather one. I cleaned it up, softened the leather up with some neatsfoot oil and it looked and works great. Pumping the throttle gives a very clear, predictable squirt as it should.
I’m no help, but I feel your pain. I’ve been struggling with the same issues. I’ve got a buddy with a smoke machine I’m gonna try out to see if/where I have a vacuum leak. 18” at about 600’ elevation and backfires out the carb under a load. I’ll be watching to see how you solve your issue.
I would think I'd have a terrible idle and bad vacuum if I had a vacuum leak, but I'm stumped. I'm out of time tonight, but tomorrow after work I'm going to start looking at fuel supply. I'll test the fuel pump, though I don't think that's it. My money is on the jets.
Or, ignition. I'm seeing some mechanical advance with higher RPM on the timing mark, but I don't think I have a very hot spark. I was having coil trouble when I first got the truck running, and I'm still not convinced I'm really burning all that hot through my 45-year-old ignition. Points are cleaned and gapped properly, but they're points and the original coil was pretty weak when I was testing things. It barely passed all the FSM tests, but I got it started after fixing the grounding issues, so I just sort of moved on. Might be worth looking at the Pertronix kit and a new coil, since it's on the list anyway. Was hoping to wait until later, as I don't want to put more money into this retard distributor. My plan was to get it running with the retard (desmogged/capped) distributor and stock carb, and address some other pressing issues.
My Innova timing light has a built in dwell meter. It’s pretty slick. I think you can pick up stand alone dwell meters pretty cheap.
When I had my carb torn apart, my power valve felt like it was catching/sticking in the bore. So I sanded the brass weight and the bore so they were buttery smooth. P3000 grit wet sandpaper. Not sure how critical that is, but it’s supposed to momentarily supply extra fuel when vac drops.
My guess is spark. Might not hurt to pull the guts out of your dissy and lube it up.
When re-checking your valves, are you slipping the feelers in while the lock nuts are still snugged down and engine is clattering away? Your feelers might get a bit hammered, but I think that’s the best way to check. I have my camera rolling as the valves are clattering and call out the valve # and whether it’s tight, loose or good. I then turn engine off and adjust valves based on how they were with engine running.
I've done it both ways. I think the trouble I've been having was that they seem perfect with the engine off, then are so tight I can't even get the gauge through when running. I've gone to pretty much doing it your way, but I'm starting to get the mojo of knowing how loose when off will translate to just right when running. I think I'm pretty close now. When in doubt, I erred on the loose side in an attempt to make sure the valves were closing up all the way.
I bought the cheap timing light, but sort of wish I would have popped for the fancy one with the dwell and advance adjuster, since it's pretty hard to tell how much advance you have on this motor. You really only have markers for 0° and 7° BTDC. Seems to run a little better advanced a bit more than 7°, but I have no idea exactly where I am. The BB is about 1/4 the way between the mark and the bottom of the window.
I have a dwell meter on my multimeter, but I killed the battery tonight. Been working that baby pretty hard the last couple weeks. I'll try to check it again soon, but it seemed ok before and my timing mark is pretty damn steady. The distributor should probably be gone through anyway, but it seems like the shaft is fine, or my timing would be jumping around.
Denso W14EXR-U are hot plugs... clean and gapped at .031”?
I swapped my ‘78 dissy to a Toyota-geared, vacuum advance DUI and eliminated the ballast resistor (Yazaki 8ga pink wire, spliced unto large BY wire), eliminated coil and igniter. Same plugs, gapped at .055” and timing at 12*BTDC.
This change eliminated a huge vacuum leak in my ‘78 dissy vac adv module and eliminated huge power loss at 6k’.
It will now cruise at 75 mph and struggled to get to 60 before.
Just food for thought.
The DUI system looks like a winner, but damn, it's spendy. We'll see. I don't have a vacuum advance port on this carb, so I'd have to send that off to get drilled out if moving up to an advance distributor. I also have a local club guy with a '86 advance distributor, ignitor, and dented side cover for me. I'll have to check with him on price. New wires, the 60 gear, and a Pertronix kit might add up quite a bit, even going the cheap route.
