All- Getting a significant howl out of the rear end now. I had to open up the diff to remove the half shafts as part of a 4 wheel disc conversion. In that process I had to adjust the diff center section to the left with those silver adjusting "cups" in order to bring in the passenger halfshaft to align the rotor with the caliper. So suspect that change has misadjusted the mesh of the gears, hence the howl. I'll crack the pumpkin again to see if I can adjust right some more, but there's a limit with fixed caliper mount vs. shoes seated in a different section of a drum.
When draining, lots of metal "flake" on the drain plug magnet. Giving you all of this background to say... I probably need a diff rebuild. How have folks approached this in terms of sourcing the gears, runs,and bearings?
I'm also told adjusting without the right instruments, is high risk....
Thanks,
LR
Thanks,
LR
