74 Fj40
Southeast Ohio
74 Fj40 Question
Hey everyone, My name is Joe and I am looking to buy a 1974 FJ40. My question is I look at many of this year FJ some have the spare tire carrier on the right side some on the left. Could someone explain the reason for this. Are they from different parts of the country or what?
I had a 1978 and a 77 for parts while I was in collage and was forced to sell due to marrage and kids. Now all of that has settled down I am looking again. I just joined this site and so far has been a big help. Any answers would be great . Also anything I should watch out for in this year FJ. I live in Ohio. Thanks.:)
_____________________________________
1993 toy 4x4 SR5
1985 4 runner
Welcome.
1974 was a transition year for the spare tire carrier...iirc.
Truck will not have disc brakes..... transition year tcase...2.313 low with a four speed instead of the 1.999 low found in the case behind the later four speeds...
If you do not have your heart set on it...I would find a later one...unless it is CLEAN.
Good luck!
-Steve
If it is a very early '74 the spare will be on the right and it will have 3 speed attached to the transition tcase.
That's what I have in my 10/73 produced FJ.
But it is still an interesting year for transitions.
Biscuit said:
... will have 3 speed attached to the transition tcase.
that would make it a three speed case...not a transition case. ;)
The 'transition' case is one that was bolted to a four speed transmission, that had the 2.313 low range/gear set from a three speed case in it.
:beer:
I have parted out jan/feb 1974 trucks that had three speed trans and the larger ujoint/bolt pattern on the drive shafts( what would be found on the four speed trucks)
Good luck!
-Steve
You went to college and still spell like that? Just kidding man, welcome to Mud and use the search liberally to find out alot of what you are looking for. I would hold out for something later that would have disc front and rear. It will make you alot happier
