74 Evaporative emission control device?
Colorado Boy-74-FJ40
I may grow older but I refuse to grow up!
Windsor Colorado
I checked the search and don't believe it helped me. (nothing for my year) I am stripping and undercoating the tub and when I disassembled the gas filler neck and tank there was this device with three fuel vent lines hooked to it and a little filter thing coming out of the bottom. Do I need it? I don't get tested and the smog pump and air rails have been removed long ago. How can I cap the lines so it wont affect anything? Thanks for any help in advance
I think this is your vapor seperator...
I believe you do want this to keep your cab from stinking like gas.
Not sure exactly how it works - other than it captures the vapors outgassing from your gas and allows them to condense and flow back into the tank...
Keep it. It is part of the evap emossions system, and PabloCruise is correct: you're more likely to have fuel odor inside the cab if you ditch it. Note how it's plumbed so you can re-attach properly.
The vacuum applied by your evap emiss controls pulls fuel vapor through this device into the manifold air fuel mixture. The "filter" you saw is really a valve that's in-line between the charcoal canister and the separator/fueltank. The valve helps regulate the flow one way and the other, because when the tank is under vacuum condition, it can draw air back into the tank through the same line to help equalize the tank pressure.
