e rock said:
I'm assuming you're leaving everything else stock? There are still a lot of variables to consider:
How much torque are you going to be making? Torque twists axle shafts, not horsepower.
What's the end purpose/primary use? If it's a street rig, you'll probably be fine with the stock axles. The stock axle shafts are similar in size to a d60, with 30 splines at the diff, but the housing is not as strong. Your front axle has coarse spline (10 spline I think) outer axles, though - unless someone has converted it to disk brakes or swapped in a DB axle.
But as soon as you put it into low range, you've doubled the amount of torque going to the axle... Which brings up another point. You WILL need a torsion/traction/whatever bar or you will turn you leaf springs into mush pretty quick if you plan on using much of that power very regularly.
For the amount of gain, don't waste your time on a 9". You'd have to be a couple grand into one before you really see any improvement over what you've already got.
I say run them and see what happens. If the only reason you're considering a swap is for strength, I'd wait to see if the effort is necessary. If you twist off a shaft, they're cheap to replace and you can start working on a D60 swap.
Just thinkin' out loud,
Eric
Thanks for the time and information.
The engine dyno tested at 461 ft/lbs with TPI. As much as I'd like to rock climb, unfortunately I live in south Louisanna, where there is no such animal, (except very small ones on driveways). The toy will be used mostly for street / strip / show, and possibly mud bogging and/or mud racing on more forgiving terrain. My thinking was similar to yours. I basically planned on testing by stages, and when breaking, then replacing. But I am skeptacle about even test running the 1/4 with uncertainty. Nothing is ever certant, but beefing up, and planning for the worst can sometimes pay off.
I find your insight helpfull.
So, if the rear axels are 30 spline, but the differential is the weak point, can I not just replace the differential? Who offers a stronger unit that will adapt painlessly? I was planning on swapping for a locker anyway!
Summay: My brother owns a jeep, and is gearing up to blow me away (yes we're a bit competative)! Presently, the machine has a mild 350 chevy, everything else stock. When he's finished, he'll be pulling up to the house to take me for a ride and boast a little. He be thinking, I don't want to even attempt putting the LC on the side of him, because he's leaped over me with his new motor and drivetrain. After he's finished, I plan on having a bit of a surprise for him!! I'll have the greatest satisfaction, when I open my garage, and fire up the little beast, and he runs over to see just what the hell, I have done to it now!! Then he'll look down, shake his head in disgust, laugh a little, then we'll take a ride in the LC to gain back the King's crown HA!!
Landcruiser's Rule!
