'73 fj40 parts
1973 Heater and Cowl Vent Doors
Rear view mirror, smog pump brackets, smog valves w/ bracket, carb linkage bracket
Note: the smog pump brackets are different. One is about 3" across, one is about 3.75". The bolt holes are the same and should bolt up to any f or 2f (I think).
The carb bracket bolts on with the port side carb nuts and holds the rod linkage between it and the firewall bracket.
I'm not exactly sure where the smog valves came from. Tell me what you want to pay and they're yours.
The mirror has no glass in it, and you can see the overspray on the plastic. Wasn't me.
What is the washer-looking thing (1 cm thick)? Where do the cap nuts go on a '73; valve cover? What about the shorter cap nuts? Toyota even? What is the bolt with the big rubber pad around the head?
Carb linkage piece
Fuel line bracket from the front of a 2f.
do you still have the tire carrier and locking mechanism available. would you ship to 94063 and how much for either or all items??? thank you
looking for 3 speed xfer case manual controls that would fit 71fj, shifters and linkage 2wd 4wd hi and lo. thanks
I never had an extra. I've just got one in my rig.
Sold. Sorry.
