'73 FJ Ignition Issue
Arlington, VA
My '73 FJ40 starts right up and runs perfect for 15-30 minutes or so. If I then shut it down, need to crank it forever to get a re-restart. Run it 30 more minutes and then it's dead. Will crank but not start. It's got a brand new OEM Toyota distributor, points, cap, condenser, and rotor. When it is running, these are the voltages I'm seeing- resistor (+ side)- 12.5 V, resistor (- side)- 7.8 V, coil (+ side)- 7.7 V, coil (- side)- 4.9 V. What do you think? Bad coil? I would think that 4.9 V going to the stud on the side of distributor is way too low.
Don’t know about the rest but 12.5 V running is low.
And the voltages are higher when it's cold?
4.9v with the points closed or open?
Sure it's not the idle solenoid thingy?
Yes, the voltage at the - side of the coil switches rapidly between the static voltage and zero. Your meter just averages this, so the reading is irrelevant.
Hot restarts can be problematic and can be due to a flooded fuel condition.
You make is sound as if it just shuts off itself and if true, it may be an intermittent problem, like a loose electrical connection.
