'72 fj40 engine runs rough
Northern VA
Hi all-
I'm a long time aircooled VW guy whose son just picked up a beater of an fj 40.
Body is '72' engine looks to be f1 from a '68.
Heres the problem:
Starts hard. Plugs/points/ rotor/cap/plug wires all new, timing within specs.
Carb is aisin, said to be "rebuilt".
Valves badly out of adjustment, so now adjusted.
Seems to have exhaust leak on drivers side of engine.
Carburetor will not respond to any adjustment of the idle mixture needle. All plugs are black, and the engine backfires every 2-3 seconds through the tailpipe.
Compression is 110-120 on all cylinders.
Plugs and no-adjust carb tells me engine running very rich, but here is the puzzle: pulling each plug wire from #1-#4 results in noticeable drop in rpm. No change when pulling #5 and #6 wire.
I'll look into why the carb won't adjust, and I'll get to the manifold bolts to tighten and see if loud exhaust sound quiets down, but can you think of why#5 and #6 act like that? Wires/plugs are good.
Thanks, Lynn Blasch
Get a vacuum gauge. Hook it up to the brake booster vacuum or another manifold vacuum port. Then let us know, or read about Vacuum 101 in the Technical Links, referenced at the top of this page.
(by the way, #5 and #6 valves are often the first to burn because they are closest to the booster, which also can be a source of vacuum leak)
WELCOME!
If you get no change in RPM when pulling #5 & 6 plug wire, it means that #s 5 & 6 are never firing. Just gotta find out why...
No response to idle mixture screw, and black plugs makes me think un-metered gas. Check the fuel level in the float bowl by peering through the porthole on the front of the carb, you should see the fuel up to the middle of the glass. If you've got a stuck needle valve or a float set too high or the two check balls mixed up it could lead to an overly rich mixture (and landcruisers are usually pretty tolerant of a rich mixture). Since you have equal compression, I would think #s 5 & 6 aren't burnt but are just getting most of the un-metered fuel. I would be inclined to rerebuild that carb. A decent kit runs 30 bucks, not much harder than a Solex.
Hard start could be vacuum leak, carb flooding, or just really bad case of timing advance [seen quite a few of these] overly tight or loose points in a worn distributor [seen quite a few of these too] One distributor with really sloppy bushings was SO BAD that three cylinders wouldn't fire unless you were LEANING ON THE DISTRIBUTOR CAP! :eek:
1. Can you determine the timing? [own a timing light or have access to one]
2. What is the lowest speed the engine will run at? [tachometer is much better than a guess]
3. What is the vacuum reading at that speed [again a guage is required]
It will be a lot easier for EVERYONE to give suggestions, rather than guesses, if you can provide this information.
"72 fj40 engine runs rough
Thanks for the replies, all.
I'll get a vacuum gage today and go to Richmond tomorrow to see what I can record for readings.
Meanwhile, I have a serious problem to report with the distributor, so let me answer the timing questions first:
Yes, I have a timing light. Timing is just a tad off the dimple at an estimated 700-800 rpm. I'll put a tach on it tomorrow.
Here's the problem-when I attempted to adjust the timing, I discovered that I could not turn the distributor at all. I loosened the clamp all the way, even removed the hold down bolts, but even with the aid of a rubber mallet and some hefty whacks, I cannot budge the dizzy.
It appears to be fairly new, with new cap, rotor, points, but I cannot determine the make or model because I can't remove it.
It also has something I have never seen:
Strapped to the coil is a 3" long, !" wide black resister -looking thing, with a condenser attached to it. This is in addition to the condenser on the side of the dizzy.
So-
Any ideas as to what the black unit on the coil is?
And, any ideas as to how to loosen and/or remove the dizzy? I sprayed liberally with WD_40, but no results.
I'll report vacuum readings tomorrow.
Welcome to mud.
A couple thoughts in random order. If the timing is off a bit there will be some decline in performance but not what you're experiencing. In particular you won't have just #5 and #6 missing.
Here's an experiment to try:
first change out for another new set of plugs (cheap ones will do great for this). If they are fouled then cleaning the old ones is no good.
With new plugs in crank up and pull the hose for the brake booster (That is, if you have power brakes). If not what we're looking for is a way of creating a large vacuum leak. If creating the vacuum leak causes the RPM's to go up and the engine to smooth out some you'll know it's because the mixture is closer to being correct. In such a case the carb is dumping in fuel and the fix is a carb rebuild or a new one.
Let us know what happens.
Rice
The black unit on your coil is what it looks like, a resistor. Means your presumably aftermarket coil does not have an internal resistor. At least for early 70s and earlier, the standard coil is internal resistor.
The issue with the stuck dizzy is a nasty one. I've not had this experience, so I won't try to advise you. Others may chime in. Look under the cap and try to find out what kind it is for us.
Right, Noobie;
The black resistor looking thing is a ballast resistor. It came stock on lots of 'Cruisers and it did a good thing, though I forget exactly what. I haven't had to deal with one for years, since I put a Pertronix igniter into both my '74s.
Please do identify your dizzy for us. If you're lucky, you have a 'Cruiser dizzy and it's just stuck. If not, you may have a Delco or some other abomination 'cause somebody tried to hot-rod that engine. The usual procedure, if you find it's not a Toyota dizzy, is to throw it as far as you can into the bushes and then throw rocks after it (do not forget to throw rocks!). You will then replace it with a cool '68 vac-advance dizzy and all your troubles will end.
A very knowledgeable 'Cruiser Guru has provided pics and descriptions of most 'Cruiser dizzys here:
http://www.rzeppa.org/tech/jimcdist.htm
Also: In your first post you mention that it's a '68 engine. What makes you say that? Check your engine number? you can do that here:
http://www.sor.com/fengine.html
Thanks all.
I'll work on it tomorrow.
Plan of action:
Take vacuum readings.
Search for leaks.
Try to unstick the dizzy.
I'll let you know if I can identify the dizzy, but hard to do in place. I'll take pics and post, if I can figure out how to do it.
And, the engine serial comes out to be somewhere post 9/69 and pre * 70.
O.K. here's the update. First, the vital signs:
Compression;
1-135
2-127
3-130
4-134
5-115
6-145
I know #5 is low but I don't think it's a show-stopper.
Vacuum readings:
Oscillates .25+/- around 118 at 800 rpm. Cannot get engine to run any slower without dying.
On rapid acceleration/decelleration, drops tp 4, rises to 22.
Still cannot adjust carb. Timing at about 10btdc, supposed to be 7.
Blocked off carb with cardboard. Slight rpm increase, then dies.
Sprayed carb cleaner at all vacuum leak possibilities. This f1 engine is a marvel of simplicity:
one vac line to dizzy, vac line to brake booster. That's it!
Spray on manifolds at #5-6 intake and #6 exhaust caused large increase in rpm. I thing we've found the source of rough running and failure to adjust carb. Son Eric and I will disconnect manifolds and see what we find. Looks like a knuckle buster and PITA because car has a 6 into 1 header system, vice standard exhasust manifold.
Anyway, thanks to all who responded. I still can't tell type of dizzy, because even with P Blaster soak and strap wrench, can't move it. It does seem to have a red-background, silver -info ID plate on the base, but I cannot make out any numbers or letters. Hoping P Blaster will eventually break it loose.
I have pics of lots of things in the engine comp but I can't figure out how to import to this thead.
I'll let you know what we find out- may take a week to get together again in Richmond.
What was that vacuum reading? 118? Is that 11.8? Would make sense.
That #5 cylinder being out of sync with the others makes one think of a burned valve, or bad valve guide. I think a worn or broken ring is less likely. But you might, when you get the vacuum leak fixed, try a wet reading (adding a bit of oil to the cylinder and retesting), and see if you can at least partially correct it. Manual recommends cylinders be within 14 inches of one another.
Sorry about the typo in the vacuum readings-
It vibrates from 17.75-18.25, with the center point being 18". Said another way, it is "steady " at that point, but jittery within the range I mentioned. No periodic drops or rises, no floating over several inches, etc.
In Vacuum 101, where you sent me a couple days ago, it says if I have an intake leak I should get a steady reading of less than 10. I'm surprised that, given the significant rise in rpm when carb cleaner sprayed around 5&6 intake manifold, that my reading is as high as it is.
Had to do compression myself, no help, so the readings were done by running to the ignition switch, trying to count the pulses to get 5 cycles, then heading for the engine compt to check the reading. I certainly could have missed something in the process, so next time I 'll check it with some assistance.
Thanks for your help on this problem. This is a GREAT site!!!
Yeah, that is a great vacuum reading. It doesn't seem consistant with the intake leak you found. Hmmm.
