71 Fj40, I Need Help!
HOWS IT GOING, I HAVE A 71 LANDCRUISER THAT IM REBUILDING RIGHT NOW, AND THE FOUR WHEEL DRIVE DOESNT ENGAGE, I NEED TO KNOW WHAT THE COMMON PROBLEMS ARE THAT KEEP IT FROM ENGAGING.:frown:
PLEASE HELP!
Welcome.
Do you have lockouts?
Are they in the 'lock' position?
Do you have vacuum acctuation on the front drive or a mechanical linkage comming through the floor next to the shifter cane?
Little more info will go a LONG way.
Good luck!
-Steve
CAPS when typing means your yelling, maybe Steve needs yelling to hear, but I'm not that old.
Does the vehicle run? Are you able to shift the Tcase? How do you know its in 4WD on the Tcase? Did you try 4WD High and 4WD low?
Are Both drive shafts being driven by the Tcase?
Guess I'm trying to figure out if it is the Tcase thats not in 4WD or the axle
is it moving when you try to shift the t-case? mine really doesn't like to shift when it's sitting, but if you get it rolling a bit, it'll go in, when I first got it I thought it was not working, but it was just me. were you familiar with the vehicle before you started rebuilding it, or was it bought as a project??
