- Thread starter
- #21
first pic was wrong (before I double checked my work late last night)...
There are actually 2 wires coming from the switch connector, only the black one is shown in the EWD (used for the shorting pin)
first pic was wrong (before I double checked my work late last night), here is how I have it wired up, the CDL switch works fine, I can hear the CDL lock up when I push the switch in high
Only the early models had the switch.Strange, my early EWD shows both of the wires, but not my latr one... Wonder why they didn't publish it later on?
It's actually this thread that had me doubting my work that lead to me putting the pin in position 8 to begin with, it was quickly fixed and is back to normal now as shown in the pic above, no damage has been done to pin 3 other than some slightly exposed wire, just exposed from the sheathing not cut or frayed or damaged in anyway, I will heat wrap and make it look nice probably never, also used a wire pick to get the pins out in addition to the needle nose pliers, not my first time dealing with electrical connectors, the pin lock is up because I wasn't done, it is down and locked now and all pins are making contact, I am going to leave everything as is and give up on the pin 7 mod at this point, my 6'2" 280 pound, broad shoulder frame can't handle digging around at the pedals anymore for a mod I will probably never use. thanks for the help anywaysAh, now you see why there were so many "are you sure you've got it right?" questions.
The next thing that needs to be addressed is that funky blue/black #3 wire. You'll need to be sure that is making good contact. I also see the connector's pin-lock isn't fully depressed. You say you pulled those wires out with needle nose pliers? That could damage the lock tab on the pin.
Can you pull the blu/black wire, remove the tape and take a picture of it so we can assess the damage?
