So I tried to do the 7 pin mod again after further researching and making sure I had the proper pin to pull and followed this pin out for reference
(top)
1,2--3,4
5,6,7,X,9,10
turns out I had the right pin the first time I tried but tried again anyways and got the same results.
After pulling pin 7 it will not lock the center diff in high or low and no lights come on the dash in either position, just drained and changed the t-case oil today and the harness was plugged into the t-case. Anyone else have this problem, any thoughts?
When I re-establish pin 7 I get the normal operation (CDL switch works in high to engage or disengage the CDL and low range is full time CDL locked).
Thank you
D
(top)
1,2--3,4
5,6,7,X,9,10
Thank you
D
