69 FJ40 Project
First time user on the forum. I am tearing apart my 69 FJ40 and know very little what to do and not do. One question that I have is the large phillips screws on the windshield and body. What is the best way of extracting? They seem quite stuck. Tried impact driver with zero success. So far, I have taken off the fenders, hood, top, doors, clutch and brake reservoirs, tires, heaters, hoses, some dash parts, steering wheel and most bolts to frame. My floor appears to be shot, while the body seems mostly good. Can I replace the floor? I had an estimate of $1500.00. Seems like I should just bite the bullet and get the new fiberglass tub. Have not yet figured out how to get the shaft from the steering wheel to steering gear box out. Also considering going to the floor shifter rather than the column. Any help would be apprectiated.
Thanks.
Welcome.
Steering shaft does not come out of the column, unless the whole steering gear is tore down. Best bet would be to remove the steering gear from the frame, and plan a power steering install.
I have needed to use a torch to get the screws that hold the windshield hinges to the frame. I have twisted many off, it happens when working on old, rusted vehicles.
Good luck!
-Steve
drill the heads of the bolts/screws off. soak in PB blaster and remove remainder of fastner with Visegrips or blue tipped wrench, depending on your speed requirements and intention of reusability.
I've taken a bolt and welded it to the head of those screws to get some extra leverage. Work on half of them, the other half broke and that was on a '70
Just did the windsheild thing a few weeks back on my "second" cruiser now. Just as Poser stated I too used a torch, a plumbers torch to be exact and then I heated the center of the phillips head until I could smell the insulation behind it getting hot. A few wacks with my impact driver and right out they came!
attachment.php
I just did a 68. I found that the rust that is stopping the screw from turning is on the head and not on the threads. I used a left handed drill bit. Some came out whole and some were more difficult. If they wouldn't screw out the heads would bust off, (from the hole you drilled). Then I would use a smaller left handed bit to pull out rest of the screw out. Make sure you put a good screw in the hole that you made so your windshield hinge won't twist on you. I used allen head bolts, worked good.
Just pulled the windsheild on my 70. All came off %$#@^ . Some did require the impact driver. Be sure you are placing counter clockwise pressure to the driver as you are whacking it with hammer. Didn't work for me until this slight modification. Dang my rookieness.
Chris
Rusted Fastner Removal Tool
I built a tool that really helps loosen old rusted fasteners.
All you need is a air chisel, one old air chisel shank, one 3/8" 3" extension, one old screwdriver and a 3/8" to hex bit adaptor. Weld'em up as shown in the pic and set your air compressor regulator from 20-80 PSI depending on what you are doing. Use the lower pressures for small screws and larger ones for small bolts. In use the vibration from the air chisel helps break the rust bond. Just pull the trigger, push hard and use the handle to turn it. The handle really makes a difference in your leverage! Keep moving it back and forth as it loosens. For really stubborn ones use the propane torch to heat it first. Don't forget to run a tap into the threaded hole after you remove the rusted fastner to get the corrosion out of the threads. Then use anti-seize on the new fastner. Be warned that if it's really stuck the tool will just chew the head up badly. I thought about getting a set of those bits that Craftsman sells for removing old messed up screws, that would help alot.
Thanks
Thank you, everyone. This projects is going to be interesting. I really appreciate a forum with a group of people with similar interests and understanding problems of a rookie.
I "will" be back.
Thanks again.
