69 Bib Markers
The p.o. removed the fender signal lights and used the front bib markers as the signal lights. The bib markers flash when signaling, but when the head lights are on, the markers do not stay on as do the head lights. How do I wire the markers so that they come on with the head lights and still signal? p.s. tried the search function and I suck at wiring:eek:
If you take you bib lights out you will see on the socket there is a place to solder another wire on it. When you do this you will need a dual filament bulb to fit this socket. The wire you have hooked to the turn signal is actually for the parking lights the one you solder will be for your turn, wire them into your terminal connectors and your set. Not to bad of a job. I did this to my 68.
Up late dudley? Do you have a diagram? Again, I suck at wiring:eek: Thanks in advance.
I work Graveyard shift. Your really don't need a diagram just pull the socket apart and a little solder. I use the '71 diagram in the Technical Links tab at the top off the page.
Brent
Ditto on the graveyard shift. Where does the newly soldered wire go to?
It is the terminal strips on your fenders. (I think 69 has these strips. I know 68 does.) The wire you have going to the bib light now will be hooked back up to the color that is on it. Match the colors. The terminal you take this wire off of you will hook up the new wire.
Brent
The lights in the bib were just parking lights and were on only in the first position of the light switch. When the switch was pull to the second position these lights went out. Once you solder in the second wire in the light socket there are two ways to keep the parking lights on with the head lights. First is to replace your 69 head light switch to a later style not real easy but can be done. The second way is to wire the parkings light to the tail lights since they stay on with the head lights. The easiest thing to do is just solder in the second wire then find which terminal on the inside fenders has power when the switch is pulled to the first position and wire the extra wire to it. My guess is you will have to switch the two wires on the terminal strip after your done because the parking light will probably be brighter than the turn signal. The dual element bulb only goes in one way and that was originally wired for a parking light, not the turn signal. You wouldn't have your parking lights on with the head lights but the sixties Fj40s weren't suppose to.
John
