'67Battery Size
Bainbridge Island, Washington
Man, I'm full of questions these days.
So with the 10.5" x 7" stock battery tray, I seem to be limited to the battery I can find. I saw somewhere in here that a group 27 was specified at some point, but the ones I see are all to big.
What's 'standard', or at least what's a minimum CCA rating? I see a Die Hard listed at 500 CCA would fit- actually with lost of room, indicating that the capacity could be bigger.
We are making progress- drove it out of the garage (borrowed battery from another vehicle).
I run an AGM battery that is several inches smaller than the tray. It has a good factory holddown on it; never moves around even on the high speed washboard of Death Valley.
And the extra real estate is useful for other accessories.
Old rule of thumb 1.5 CCA per cubic inch minimum. 240x1.5=360 CCA. 500 would give you 2x the CI.
More importantly is the Reserve Capacity which is how long the battery can manage a 25A draw before the voltage drops below 8v. In cruiser terms, how long you can drive if your alternator dies in the middle of nowhere before you’re hiking out.
I’ve got 1050 CCA for my 350 and 210 min reserve capacity. It’ll start the 10.25:1 motor (I had) without the headlights dimming and if the alternator failed I’d have 3.5 hours to get back to civilization. That said it’s a 31 series and kinda like two batteries in one.
1) I personally like the biggest battery that’ll fit into the tray... but as Mark points out, that extra space can be used.
2) Don’t buy a cheap battery if you like remote places... spend a bit more and buy a decent one.
