'67 fj45 build thread
Santa Rosa, CA
I tried search, but I got too much that wasn't relevant.
I'm looking for a list of tasks and parts to do a chevy V8 swap on a 67 40.
Here's what I have to start with, but I want a more detailed list. I am sure there are many lists on here, but I just could not find one.
gas tank with swap appropriate fuel pump
Remove engine and tranny and xfer case (and get xfer case rebuilt and adapted for 4.0 gears)
Remove all existing mounts
Power wash, clean the firewall,
Sound and heat treat the firewall and down to the underside of the floor plan
6.0l/4l60e engine complete with gas pedal, harness and computer.
engine mounts/cross member
trans mount/cross member
xfer case Adapter
Headers
02 sensors (will need a cat and muffler)
radiator with hoses
Electric fan - double fan with shroud
Trans cooler - Separate from the radiator - and trans lines
AC condenser
Gas pedal
Computer mount
Drive lines
Gauges (water, oil, speedo, fuel, tach, etc)
HPTuner the tune
I don’t think you will find a list that will work for everyone. Your list reflects your build. As you get started, it will change almost daily as you accomplish tasks and move forward. Parts availability will be a major issue and lack of funds can also crimp your style.
Have fun and good luck.
Thanks for all the input
I looked at the Advanced Adapters info, I'm looking for something more specific and detailed than what I found
I run cats to get rid of the smell, not for anything else.
I'll look at the pan
I'm looking to run a relatively new 6.0, so DBW
Good info on the tcase. Something more for me to buy.
I'm definitely on the look out for good motor mount options. I've seen them with integral cross member that I like.
A dog is spot on. Your list is a good start. Once the driveline is installed it will nickle and dime you till the end. It will be specific to your conversion. Like relocating the battery, heater hoses, recovery tank, driveshaft alterations, exhaust, etc. I'd figure $1500-2k or more to finish the job.
@Lil'John - so I'd love to see that design for linked belly pan and how it relates to the motor mounts. I may want to link this in the future and I'm trying to think about what I need to keep in mind now.
@workingdog don’t you have a 40 with a 6.0 already? Are you building another?
2X on skipping the cats. You just need the upstream O2 sensors. If you are using a donor PCM that was in a production vehicle, you'll want to reprogram to delete everything except what you need to make the engine run. Otherwise you'll be wading through codes every time you hook up a scan tool.
@cruisermatt - Yes, actually, I was stupidly trying to be subtle. It found a 67 FJ45 in Tuscon (that used to be in California) virtually all original. I didn't want to say, because I know I'm going to get abuse for not doing a restore on it. And it's good enough, it deserves a restoration, I'm just not that guy. This is going to be my DD, more streetable, for things like trips to Death Valley and Baja. We are going to move the 40 to 40's and make it more of a crawler. At least that's the plan. I say we, I mean me and my 16 year old son, who won't really help, but will have lots of ideas for paint schemes with flames cool 50" bogger tires he saw on Daily Dirt.
The big difference this time is that I'm going to do all the work myself. No more paying for it to be done - at least that's the plan. I'm sure I'll need some help for things like fabbing cross members. This will be my first real build, and it's going to be a real push/challenge for me.
First phase when it gets here is to do power brake conversion and saginaw conversion. But those are straight forward. Once it's drivable with the 2f, I'll move onto the engine. I'm scared of the engine swap. I'm scared I'll get started and 3 years from now it will still be not done. So, I'm trying to get everything lined up so I can pound it out in a few months. I'm going to be doing this outside, on the gravel in my side yard, which is going to be it's own set of challenges.
Another thing I wasn't completely honest about. I'm planning on doing a 6.2l/6L80 combination. The idea of that powerplan and trans in a 45 makes me moist.
@cruisermatt
Hell yeah, you can do it this.
But I would stay Gen 3 unless you’re going to do something like an EROD. The used pullout Gen 4 stuff has enough quirks with AFM/DOD and trans control that it could end up taking forever. Not saying it can’t be done, it can, but Gen 3 is just so much more commonly swapped. Throw a $250 cam in a Gen 3 motor and you’ll have stock 6.2L power.
You know, I have a cam in my 6.0 and I hate it. Took me forever to tune it so it was drivable.
But, the 6.0/6l80 is half the price of the 6.2
What do you hear about AFM and DOD?
@Lil'John - help me out with lingo. When were 34mm and 38mm cases produced? I'm not up on the history of transfer cases in LCs.
I think the cam I had was just too hot. And, help me out. In a rig that's going to spend all it's time below 3,000 rpm and a lot below 2,000 rpm, what's the advantage of a cam? Don't they start making power at 4,500 rpm?
I am definitely not racing this thing and I'm not one of those guys that lines up on a ledge and punches so you can him him miles away. I'm much more of a finesse guy - although my kids would say I'm more awkward than finesse.
That completely depends on the cam profile. For more low-RPM power at look at the “Tow cams” or “torquer cams” from various manufacturers. Other then that the way to make bigger power at lower RPM is with bigger displacement or longer intake runners.
Love the picture. Thanks for the info about the cams. that was useful. Mine was stage 2 car cam. Not the right thing. So, the cam you are using idles just like stock?
Another possibility for that......
'65 FJ45 with LQ4 and 4L80
Yes, this thread has convinced me to with 6.0/6L80 which is the modern version of that very pretty cruiser. That's exactly what I have in my 40.
@OldRocDoc - what hydroboost set up is that. Looks very clean and small and it fits next to the rib. And what's that red thing on the right side of the radiator. And, how's the radio on end. And ... what kind of top down radiator mount is that? So many questions.
Don't forget that the axles on that '67 are course spline and will break with any serious throttle. Front 'fork and ball' will fail first. Highly recommend disc brakes and later axles/birfields. My experience comes from a GM 350 swap into a '66.
Good luck and keep us informed of your progress.
@ferg - Yes, I realize ball and claw is an issue for 67s. I'm either going to eventually put the 45 on the fj60 axles that are current under my 40 (and take the 40 to dana 60's) or put it on fj80 axles - if I can find some. But, I'm trying to break this down into phases that can be done and then the rig back on the road for a while, axles are going to after the engine/transmission.
The hydro boost unit is GM (taken from a 2004 Silverado) with a Vanco master. The red bottle is the radiator overflow and the radiator mounts are my own homemade units. Not sure I understand the question on the radio.
