'66 fj40 Frame Off Buildup - TJ's Cruiser
Finally got a chance to work on this build this weekend, though I had to work quite a bit of the weekend. Didn't make a whole lot of progress but going to post it anyway :p...so I can blow the dust off of this thread.
Working on the Saginaw gearbox mounting - got a tube from Cruiser outfitters to recess the gearbox into the front crossmember, but had to ream out the hole in the crossmember that I had originally drilled that was too small. There was an issue with the gearbox fitting into the tube that I settled in this thread:
https://forum.ih8mud.com/40-55-series-tech/437688-flange-saginaw-gearbox.html
I ended up grinding down the retaining collar or spanner nut on the gearbox, which ever you want to call it.
I have the tube fitted in the crossmember and notched the crossmember a bit to allow clearance for the first hydraulic hose. However, now I'm having a problem with how to mount the gearbox. Working that out in this thread:
https://forum.ih8mud.com/40-55-series-tech/448854-saginaw-gearbox-mounting-issues.html
It's been a long while since I updated this thread, but I haven't been completely idle on this project. Got the balanced and rebuilt 350 back, and it's ready for the MPFI. Also, after buying an Eastwood 175 mig welder a few months back, I finally felt confident enough with my welding skills to weld up the power steering bracket and the front leaf spring mounts.
After next week, I have two weeks off and I really plan on digging into this thing.
Tacked in my Metaltech premium sliders...will also be tacking in the forward and rear roll cage tie-ins I bought from the same company. Also have set of tube fenders from them, but these are bolt-ins.
Fabbed up a mount that attaches to the bottom of the adapter between the NV4500 and the transfer case. It's a hard mount but the tubes on either side that are attached to the chassis have bushings.
And finally, today I had a local guy come over and bend up some 1.5" .12 DOM tubing for the rear fenders. I had to cut the fenders out for tire clearance - this made the bends really hard to make look right, but he did a fantastic job. Next up: building up the front tube fenders.
Also yours looks to be a 1965. If i'm reading your VIN correct it was built in feb-march 1965
A month before my 65
Thanks for the encouragement.
My title says '66. Did I give my VIN somewhere in this thread?
Personally I wish it was a '67 - my birth year :).
That picture of the passenger side frame horn shows the frame number pretty clearly. It looks like FJ40-33547 to me. Like DAD2SIX said, early 1965 production.
I had forgotten that the VIN was stamped there. It is indeed FJ40-33547. I guess you got the date from Specter at http://www.sor.com/catframe.sor. Is it possible that this frame date is just when the frame was built, and not necessarily the model year of the cruiser? The cruiser itself could have been built up later and sold in 1966.
