Update?
Mocking up the tranny. It's sitting higher than I thought. The transfercase shifter is pretty close to hitting the floorboard and it's hitting the side of the tranny hump. I need to make some adjustments.
The 73-78 FJ40 transmission covers are a close fit and are taller than your FJ45 transmission cover. Probably find someone local to let you borrow one to see if it will help you or not. I'm planning on using one in my FJ45 but I haven't mock fitted it yet. My plan is to use a A440F (FJ62 tranny) with a split case but that's not set in stone.
Thanks for the info. I thought about doing a body lift too. We'll see what happen after I put the body on again.
Go for it Stu! 1" body lift made a big difference on my 45 and the red one that I've been building for 45dude.
And, in case I forgot to mention it before, your price is.........FREE! Call me over to the house when you've got things ready to bolt back together, get some beers rounded up, and I'll bring some of my poly spacers with me.![]()
Don`t know what you have in the States.
In Germany Mercedes have a real good chassis paint for their trucks.
Cheers
Peter
.... and a special primer for the chassis paint I think.
I'm going to try the Eastwood's Internal Frame Coating for inside the frame.
Fluid Film doesn`t hurt your coating...I used/ use this product
Automotive and Industrial Lubricant/Corrosion Prevention - Fluid Film
You can get it in the USA too.
Cheers
Peter
