62 ignition issue
North Tx
My ignition cylinder works but the housing it sits in is jacked. It won’t start unless I hold pressure on the backside. It’s like the housing just doesn’t keep it tight enough. Ever come across that before?
remove the 1 screw in above pic, there is a flat rod that sticks thru between the ignition cylinder and the electric part, check it and it's function
it may also be the ignition switch itself along with said above connection.
Are talking about this part of the cylinder ?
no I'm not, that piece doesn't rotate when you turn the key
remove the screw and remove the black piece with all the wires, it will make sense when removed
the ignition switch does not directly engage the black piece with the wires, there is an intermediate shaft between the 2
So remove the nearly 40 yr old plastic white piece from the black piece without breaking it. Will try. Thanks.
I've never taken that assembly apart further. If bad I would replace, but I have spare parts.
you can try and start the rig by using a screwdriver in the slot and rotating it
is the plastic slot worn where the metal tab goes into it? it should be a snug fit
does the metal tab have play in it? does it rotate smoothly when the ignition key is rotated?
you can remove the ignition barrel and inspect the connection between them
It starts easily with a screwdriver. Also starts with the key assembly as long as I push in the black piece while turning the key
With only that single picture that you posted to go on... not having actually seen it or touched it or observed the symptoms first hand I will not say I am positive... but I do have fairly high confidence that the ptoblem is as simple as the little piece pf black plastic that the "flattened shaft" engages being wallow and worn to the point that the tip of the shaft is not engaging solidly unless you are pressing it together.
Simple fix... replace the switch. Not the lock cylinder, the plastic switch assembly.
If there is in fact internal wear... there will be eventually anyway... this problem will also be solved.
Mark...
Kind of what I was thinking . Thanks
