60 series....Tech and Classifieds
The AC idle-up solenoid is probably dead if everything is hooked up properly.
Is that the round thing or the thing on the drivers fender?
@beno is it available?
On the fender. It should have two vacuum lines. One to the carb and one to a vacuum source.
I think they are not available anymore, but some other application was found that works.
If you have to, you could turn the blue knob on the AC amp down to the minimum rpm and then turn the idle up a little.
Natalie saw a navy blue 60 with Washington front plates on meadow brook?
I saw a dark blue one with a roof rack for the second time in ridgeland. Outside of the blue turd, it's one if the best looking 60s I've seen in town. Did not get a look at front plates. I was on his/her 6 both times i saw it.
You get er done?
I nosed mine into the shop. Gonna look see if I can tell what is what with my A/C not idling up the motor.
Yes, just changed fluids in both diffs, the transmission and the transfer case. They were all due, but only the front diff was bad overdue. I need a mechanical pump. My hands and wrists are tired...like teenage boy tired.
Well dr collins has a nice 60. Natalie wont shut up about that bodystyle and color.
In madison. Who dis?
I cruised to Canton to fill up the 60 with Ethanol free.
I hope yours gets better mileage than mine @pmccraney
I put 13 gallons in and went 120 miles.
A/C is still wacked. Gonna have to start throwing money at it again
Can you compare with Patrick's? Is his a later 60?
Coolstream (first link) lists them all as '81-87, though they could be wrong.
If you can find the Denso part#, Amazon & Rock Auto usually have it.
Well, I made it to tallahatchie county and back. I got about 14-15 mpg. Truck did great for the most part
Took my time:
Did a little work (friends Hundo doing heavy work):
Checked the dove field:
Grabbed a nice Sammy here (roast beef on wonder bread):
The pig tail did not play well with the trailer - it blew fuses on my brake and turn lights.
Also, my temps have been good and not acting funny ever since I dropped in the new t stat and radiator about 2 months ago. On the way up, it was steady and never rose above half way (about 185-ish). However, on the way home my temp gauge spiked and pegged on the red for (3 different times about 20 mins apart and each for about 10 seconds before coming right back down). Weird. I'd love to fix that because it freaks me out.
Yeah, I had a little less than full tank when I left. Drove there (roughly 115 miles); drove around a good bit while there and then drove back to greenwood (25 miles) and still had a half tank. Filled up in greenwood on the way home and its sitting right below "f" as it sits in my driveway. I drove like an old man though.
