So, I walk out of the gas station to hop back in my Cruiser, and notice that I have a stud/conewasher/nut missing on my FF 60 series rear axle... I drive it back, check the remaining nuts, they are ALL tight...
dd113? Is this similar to your mishap?
Not too worried about it... this setup has 1500+ miles (almost all wheeling, or on the way to wheeling)... and I havn't checked the nuts since the day I assembled it (early this year)
What do you all think?
I can tell you that the stud didn't fail as result of shear stress, both because the other 5 studs are intact and the two alignment dowels are intact as well... also, the break on the stud doesn't look like a shear breakage patter (Mat. Sci. / MeEn Standards)...
So I am thinking one of the following happened:
1. The stud was OEM (20 years old)... it is possible that is has been stretched over the years and finally reached its limits, could have even had an existing crack from... I didn't look that close.
2. It physically hit something out on the trail... such as a rock... Not too sure, there is no evidence on the axle flange, rim, etc (but it is hard to tell as my rims/beadlocks are covered in rockrash)
