6" lifts...whos running them?
vansterdam, BC
so just checking to see who out there in 80 land (worldwide, not just NA) is running a 6" lift? tried to search the registry and the 80 forum in general...not much luck. so if you have/had a 6" lift..got some questions for ya:
1: which setup? slee, ome, king, ironman, custom, _____?
2: if you're running stock arms, what are you using for caster correction? plates, bushings, drop brackets or a combo?
3: which shocks (got p/n?), were ome L's long enough?
4: did you need a rear DC shaft?
5: are you still running std length panhards?
likes/dislikes? some pics? before/after/flexing?
thanks in advance...:cheers:
I have a 6" on my old LC. To answer your questions:
1. I bought Everything from Slee.
2. Running Slee's first generation arms.
3. Uses 2 N73L and 2 N74L OME Shocks
4. My opinion is yes on the DC rear shaft with a 6" lift. I even run a DC front shaft. Both from Slee.
5. Panhard has been cut and lengthened with a Slee adjustor. If you don't lengthen your PH your axle will not sit square under the vehicle.
Slee sells a quality product and I would have to say that 6" is not too much lift if you do it right. You have to look at this as not just one thing being important, like castor correction, but everthing. All issues need to be addressed to be safe. DC Shafts, castor correction, adjustable panhard bars, adjustable upper rear control arms for proper pinion angle, longer SS brake lines, dropped sway bar brackets, etc....
My complete Slee system will be for sale shortly. The truck it is on is now a parts truck.
I'm also running Slee's and agree with MSGGrunt. You're going to need F&R dc shafts, Ls are long enough, adjustable F&R panhards, you need to adjust your relay rod and do wheel alignment. Depends on your budget, type of wheeling and skills, there are other options out there which you already know. I'm currently looking at Ironman 6" suspension lift but need more information and input from wheelers whose running them. Good luck!
thanks for the input guys. i scored a set of 6" coils locally off a JDM. ive already got LT plates but im not sure if they offer enough correction for these coils. and already have a front DC shaft. i was comparing the slee & ironman kit to see whats all in on their 6" kits. looks like neither have the rear DC shafts included. wouldnt the adjustable UCA's somewhat negate the need for the rear DC to achieve optimal rear pinion angle? or is the DC one of those 'depends on your ride' things..? and with the rear DC, same as front? use a taco joint?
the PO of my coils was just running stock arms with bushings, so ill have to pick his brain a bit more. no budget for front arm$, and panhards dont seem to difficult to lengthen. they're a touch off center now, but with 2 more inches im sure it will be more noticable and perhaps affect driveability. already have extended SS lines, and brackets for sways & ebrake are lil easy bits to fab up. MSG, is you kit going as a whole or are you parting it?
any pics or ROTW/F's from you guys?
thanks again...
with my plates you are going to be light in caster for sure. I'd expect you caster to be around -1~0* after they are installed.
Before going with upper adjustable control arms I'd extend the Lower control arms by sleeving them. This helps the pinion angle for a stock shaft, strengthens the arms for rock contact and helps better position the axle so there is less rubbing with larger tires (37s). I've read that an extension of around 3/8" is what works best.
When I got my truck it had the 6" coils, rancho adjustable shocks that were shot, castor correction bushings, adjustable panhards, and stock driveshafts.
The driveshafts or rear improper pinion angle caused no driveability or wheelability issues but the improper castor angle caused the some interesting highway quirks.
Here's a pic of how I got it:
Slee 6" springs (front only)
Slee Gen. 2 arms (most people who say Gen. 1 actually have Gen. 2 arms....Gen. 1 arms kinda were adjustable)
Pro-comp ES3000 shocks in the front (cheap 14" shocks to see how much shock I could use up)
Stock front and rear shafts and no vibes
Stock front and rear panhards
Needs better front shocks, want to adj. panhards for aesthetics, want a torsion style front sway bar (currently front sway-barless).
thanks again rick. yeah i figure the plates might leave me a bit shy. i might try them out and see how they work out, then adjust accordinly starting with lengthening the rear LCA's...3/8" check. is there a good way of calculating the length needed for the PH's?
hey thanks andrew. was just gonna pm ya and ask what else you had on your 81 to run these bad boys. so you got no vibes with the stock shafts whatesoever? i think i'll just slap em in and see how it goes. i think my plates compared to your bushings might hopefully make less interesting hwy quirks. i just need to get some longer front shocks, might go with the same 5125s that im running out back with adapters.
i shoulda bought those wheels when you had em for sale a while back...i love those rims!
I had no d-shaft vibes at all.
I liked the wheels too, but they just don't stand up, there would have been no lip left on them by now and I do find I fit through more narrow trails better now.
If you know anyone with the castor correction arms, it would be pretty simple to build your own at a fraction of the cost.
Is there a good way of calculating the length needed for the PH's?
It is pretty easy to calculate the length of the pan hard as the height increases using simple trigonometry. You need to know either the lengths of two of the three sides of a right triangle or one lenght and the angle.
For example for the front panhard, the PH is the longest leg of a right triangle, while the height increase over stock and base of the triangle are the other two legs. The stock angle of the PH is zero, so the base is the same lenght as the PH, which happens to be 32 inches. The formula used to calculate the lenght of the panhard as the lift height increases is:
: A squared + B squared = C squared
Where A = lift height, B = 32 inches (the base of the triangle) and C is the lenght of the PH at the height you want.
6 squared = 36.
32 squared = 1024
A^2 + B^2 = 1060 = C^2
So then you take the square root of 1060 to find the lenght of the panhard at 6 inches lift height, which is 32. 56 inches. So the panhard length needs to increase by .56 inch on a 6 inch lift.
You can also easily calculate the caster change. The control arm pivot to the center of the axle distance is also 32 inches. You want to increase the height 6 inches. Divide 6 by 32, which is .1875 and then use the trig function arctan or inverse tan or invtan (which means the angle who's tangent is .1875). This will give you 10.6 degrees, which is the amount the caster changes with a 6 inch lift. This would be the amount you would get using both 7 degree caster plates and 3 degree bushings.
Full Slee 6" kit, Gen II arms (as Alkaline said, these are the tubular style, not the latest ones), adjustable panhards and rear upper control arms.
'L' shocks are fine, but I will probably space the rears down at the top to allow more down travel.
I run a standard rear driveshaft (although it has thicker tube) with no problems. I adjusted the rear axle to point above the t-case, in a broken-back configuration, to get the pinion out of the rocks. There were no vibrations with it either this way or in the standard configuration.
I adjusted the panhard bars to center the axles, wheeled it, rubbed tires really bad, so adjusted both panhards to approximately stock length. This is difficult for many people to understand, but when you stuff a wheel the panhard forces the axle to one side or the other. If you lengthen it to compensate for the angle when the truck is lifted, when a tire is stuffed the longer panhard will push a tire into the frame. This was more evident on the rear axle. If you want the rear axle centered, you need to add a bracket to get the panhard level at ride height. You can't really do that with the front axle as the panhard needs to be parallel with the drag link or you'll have bump steer.
I disconnect the passenger side front bolt on the radius arm for more flex. I do not have a front sway bar. There's quite a bit of body roll.
Sorry, I don't have pics.
!1: which setup? slee, ome, king, ironman, custom, _____? Slee coils only
2: if you're running stock arms, what are you using for caster correction? plates, bushings, drop brackets or a combo? Stock arms with Slee castor plates. Rides fine.
3: which shocks (got p/n?), were ome L's long enough? 14" travel Doetsche Tech Prerunner 8000 Pn 8421. No L's are not long enuff.
4: did you need a rear DC shaft? No but I need a front.
5: are you still running std length panhards? Yep
It's awesome! Clears stuff lesser lifts would hit. Makes the 80 look bad ass!
Unfortunately he has a set of plates with the original drill position. If the tie rod isn't rubbing on the arms now it will be once the OME bushings are pressed in.
is there a big difference with the new drill position? does it offer more caster correction? my tie rod isnt currently rubbing on the control arm at the moment. dont really plan on pressing in new bushings, just keeping the plates..see how that goes. springs are easy enough to swap out if they dont work out...
good to hear...pretty much what i was hoping to hear as well. no wandering or darty steering on the hwy and abrupt lane changes in panic stops? seems like same thing goes for the 6 inch as it does for the 2.5~3"... some need this and others need that.
:cheers:
need more pics!
The new position doesn't alter the axle's location or rotation at all from the original one, it just drops the arms down to provide more gap between the tie rod and the arms. Which might make combining bushings with them an option as suggested by Pin_head.
In my case yes. All I needed was castor plates. No wandering, no white knuckle driving, perfectly centers after turn. Highway driving is a dream. Before I was just running stock arms with OME CC bushings and it drove like a human death machine. I almost rolled it on the highway 3 times. Scary stuff. After I put the Slee plates on it drove 110% better. Which amazed me because every one said I needed the $1000 Slee arm. I even had my CC out ready to order at one point. Glad I didn't! I think it drives better than when I was running CC bushings and 2.5 lift.
I can drive with my knee now, before forget about it.
Slee full lift, Gen II arms everything adjustable that can be
1 inch slee spacers up front, soon to be metal tech 2"
Gen II arms
No Idea were on the truck when I bought it, seem to still work and no identifying marks on them.
No not yet, if I ever have free cash I might but who knows doesn't seem like it needs it.
Nope just eyeballed it to adjust them.
Love the height, no dislikes
I don't have any before pics as the PO did all the suspension on it.
Some from the PO
two from me
1: which setup? slee, ome, king, ironman, custom, _____? Slee 4" rear springs netting 6" fully loaded with a 1" spacer. Front: Slee 4" front springs with a 1" spacer, netting 5.5" lift. (26" Rear/25.5" front center of hub to flare).
2: if you're running stock arms, what are you using for caster correction? plates, bushings, drop brackets or a combo? Slee caster plates, seems to drive fine, maybe low on caster, need to get a caster sweep done.
3: which shocks (got p/n?), were ome L's long enough? Fox 2.0, 10" travel with eye adapters, about 1.5" longer than L's. I thionk L's are too short for 6" lift.
4: did you need a rear DC shaft? Yes, Slee, with a Toyota DC, not Spicer, with adjustable UCA's.
5: are you still running std length panhards? No.
likes/dislikes? some pics? before/after/flexing? Love the extra clearance. Drives great for waht it is. I still have some rear vibes that come and go. I need to have the rear shaft checked at the driveline shop. I want Slee's front control arms to get the front axle arranged better due to the bump stop inside the left coil spring hitting the spring itself. I have since then added frame mount progressive poly bumpstops and have removed the inside bump stop.
Running Slee's full 6" kit.
Gen II arms.
Currently has L shocks on it, will be replaced with some longer shocks but I don't rock crawl it much so they work fine for now.
Adjustable panhards.
DC shafts front/rear. Also have Slee's steering setup.
Zero complaints. Slee makes great products and the truck runs/drives fantastic. I think there is over $4500 in receipts though for the suspension, so it is not cheap by any means. It is my wife's daily driver, with bias 37" Creepy Crawlers on it...no complaints from her either.
I don't have any flex pics, just a poser in poor light in my driveway.
