#6 injector replacement question
Touch the meter probes together to get the inherent resistance of the probes/test leads etc. Deduct that from your readings.
Seems like the resistance is close enough to what it should be (not open circuit). So, sticky injector or something else...
I presume distributor is good (rotor etc). You have measured the resistance of the spark plug leads?
cheers,
george.
15 for cylinder one...
Today I replaced the relatively new cap and rotor with new Toyota cap and rotor. I replaced the Denso iridium plugs with Delco copper plugs. I have not tested the wires.
I really do appreciate your help
Well, seems like your wires, plugs, rotor (latter being new) are in reasonable condition. Injector resistance appears reasonable as does #6 spark lead.
You could listen to injector #6 and #5 (for comparison). There are mechanic's stethoscopes or a screwdriver :)
cheers,
george.
I'll get one.
Just took it for a ride. It does run better. It didn't seem to have the skip. The idle is rough though. The front O2 voltage at idle is all over the place. .110-.804.V. The downstream is steady between .060-.080V.
We have had good luck several times identifying troubled injectors by listening to the with a HF mechanics stethoscope. Not complicated at all. Just compare sounds to other injectors.
Truck was running "OK" this morning so I took it to work. I started it after work and the idle was very rough. I gotta get it home. As I started driving, the skip was bad. Then it smoothed out. Then the temp spiked. The exhaust smells like raw fuel. That's new.
Temp spiked? Only one thing that can cause a temp spike, low coolant. Coolant came out where, and how low was it? Run a compression test on it and see where the cylinders stand. If you find anything amiss with that, do a leak down test on the low cylinder.
How about if an injector is dumping fuel? The exhaust smelled like raw fuel. It's hasn't done that before.
If a spark plug is not firing then you'll get raw fuel too. Since your #6 plug looked so different than the other 5, something is going on with cylinder #6 combustion (spark/fuel/HG...).
If I was you I would get a HG test kit and at least (hopefully) delete that from your suspect list.
Temp spikes/overheating can also be a HG (or cracked block etc) problem.
When my #6 injector went open circuit, the vehicle ran quite rough at idle and smoother (but obviously NOT well) at 20 - 30 mph (limped home from a mile or two away when it happened). Why not unplug #6 and see how it runs - that will give you an idea of what a totally non-functional injector feels like.
cheers,
george.
I did the head gasket kit test and it came back ok. No change in the color of the blue liquid. I will investigate the injector some more tomorrow and I'll check that #6 plug again that I replaced this week. I'll also try to get my hands on a compression tester.
Yep. All ignition components except wires were replaced with Toyota parts the other day. We tested the wires, which are pretty new and they came back well within spec. Now it seems too much fuel. But it's like the chicken or the egg. Is it too rich because of the exhaust leak freaking out the O2 sensor? My issue seems to be isolated to cylinder 6, so all I can think of is either bad injector or head gasket. It doesn't steam, the plug wasn't steam cleaned, no contaminated oil, and it passed the HG gas test, before my overheating tonight. Might be a different story tomorrow.
