peesalot said:Marlin's have the torx head on the stub and he gives the socket with purchase.
peesalot said:I asked , not yet. Had the arms on the table so he must be hopeful.
Poser said:Junk OEM piece....
Wooptie fing do if they are butter bolts and shear off?
Has been 'hopeful' for over a year or so...
Sales drones at Marlin know nothing about them....
65swb45 said:I overheard somebody say something to Marlin at Rubithon to that same effect. Marlin very calmly spent two solid minutes comparing and contrasting his studs to OEM. Seemed to satisfy the listener completely.![]()
Poser said:
dustin said:[ edit ] - heh, bill, you beat me to itGlen is also running smaller/ older (like maybe LC coarse spline or soemthing with a smaller bolt pattern arms too) I think that was one reason he went with Lukes arms as well, since Luke is one of the few to make hi-steer arms for old LC knuckes? [ /edit ]
so, kinda off topic, but a little bird told me of an idea he has that sounds so right on and simple, it has to work. Luke from 4x4 Labs is planning on "keying" the steering arm to the knuckle. I dont have ANY specifics, but I think he is going to machine the knuckle and arm, and use a "key" - such as a piece of 1/4" steel bar maybe? to keep the two pieces aligned, taking alot of stress off the studs. Sounds pretty killer to me. I LOVE his steering arms, but see alot of people shearing studs with them. My fried Glen seems to make a hobbie of it. I am in line for Lukes new arms and knuckle when he starts making that set up.
cheers-
Dustin
sine80 said:That makes sense liking on the pass side running a key from the underside front of the arm atop the kunckle to the rear. I see how that might take some of the stress off the studs.
speaking of the studs, arent the coarse spline studs (early pattern) smaller than the later stuff?
Poser said:The pre 1979 Land Cruiser knuckle studs are 11mm diameter and have a smaller pattern, and when used for hy-steer systems, fail regularly, and is why most folks that have an issue the first time around, upgrade to the larger knuckles, and is also the reason why Luke is the only one making arms for those knuckles...
The key idea is great, and has been used by Crane for a few years on their Dana 60 hy-steer knuckles....hands down, the strongest set up on the market.
Poser said:The key idea is great, and has been used by Crane for a few years on their Dana 60 hy-steer knuckles....hands down, the strongest set up on the market.
this picture has been around for over ten months now whats going on with these , i called marlin and his monkies cant tell me anything ?Texican said:
hendo said:this picture has been around for over ten months now whats going on with these , i called marlin and his monkies cant tell me anything ?
same thingPoser said:Go to PPB....there is a thread there that tells the tale....
