6.0 Excursion - The LX Replacement
This last week was a thrash but the Ex is now fully bulletproofed! It had a BulletProof Diesel EGR cooler installed previously so it was "semi-bulletproofed" already when I bought it.
I packed up the kids and wife and dog and went to my parent's house outside Charlottesville, VA on Tuesday night to use my dad's shop to do this job as it was the only place that was big enough to park the Ex inside and use the lift. I decided to do this body-off instead of doing it body-on and I'm glad I did. Having the body out of the way made access 100x better and saved my back from being even more sore. It was a hell of a learning experience working on my first diesel but was fun.
The parts list is above more or less but in short:
- New Kill Devil Diesel o-ringed heads
- New Mahle HG's and full top end gasket kit
- ARP studs
- New Delphi lifters in front half of engine. Didn’t pull trans/rear cover to do the rears but they all looked really good.
- Rudy’s chromoly 6.4 pushrods
- Dieselsite stand pipes and dummy plugs
- KDD Up-pipe
- IPR Stainless HPOP screen
- New S&B body mounts
- Lots of other smaller stuff replaced.
The job went relatively smoothly but ran into some issues. One of the brake lines for the FL corner twisted off at the distribution block which I was able to source locally from the dealer. I later discovered that the other 2 lines (FR and Rear) are both discontinued from Ford so I was lucky to break the one I did I guess. Then I broke a rocker arm clip which I was able to source but had to go to Richmond to get. Luckily, my parts guy (Dad) was kind enough to make the trip so I didn't have to take 3+ hours off.
Besides those two things, the head cleaned up nicely but there were signs there was a HG leak previously so it's a good thing I did this job now. After I got it back together, I pulled the FICM relay and did some cranking until I saw oil pressure register on the gauge and some ICP pressure and it fired off shortly after. I had some hard starts after letting it idle in the driveway for a few minutes so I went and drove it hard for ~5 mins and then it started right up after that so I think there was just some air left in the HPO system. Overall, it was a resounding success! No lights, no codes, no issues on the 3.5hr drive home. I call that a huge win!
I also bought an Airlift vacuum coolant tool which is my new favorite tool. Works so well!
My wife's first day back to work from maternity leave was today so I was up against the clock to get the job done, tested, and get us all back home. Between balancing my day job and some child duty, I was able to get it wrapped up yesterday afternoon.
Some pics!
Impressive work to get that turned around so fast! It seems most of the things you replaced are for long term maintenance / reliability but out of curiosity what kind of gains do you get with the new heads?
What brand vacuum filler did you buy and use? I need to buy one for the cars at a minimum, but filling trucks with a vacuum filler would be ideal too.
- ARP studs
- KDD Up-pipe
- IPR Stainless Oil Cooler screen
Some pics!
Nice!!
The new heads are o-ringed whereas the stock ones aren’t. The o-rings can help maintain the HG seal during high boost to keep HG from blowing. The factory heads also all crack and these shouldn’t. At least for the foreseeable future.
I bought this one. I used it on the Ex and have had to add Zero coolant since initial fill.
Are you upping the boost?
At some point. These motors blow head gaskets normally at stock levels though so the new heads are really just to ensure it doesn’t happen again under normal use or even with a slight boost increase.
Plus I like shiny things
I had noticed a transmission pan leak shortly after doing the heads. By that I mean, the existing leak was now dripping onto the ground. I addressed it this past weekend with a 6.4 style transmission pan and 6.4 filter along with new gasket and MC fluid. The 6.4 pan/filter is a cheap upgrade for more capacity and better filtration over the stock 5R110 setup.
Now to address what I think is the engine oil pan leak...
New front brakes. With First Brands Group going out of business, it was tough to find NEW calipers but found some SKP calipers that were new and put those and some new Akebono ceramic pads and PMF stainless lines up front. The truck stops great now!
I bought a full set of PMF lines so the others will get installed when I do rear brakes next.
I also have oil running down the back of the engine and collecting on various things like the front driveshaft, the bell housing, starter, etc. which I think is either the turbo drain line or something in the valley since it wasn't this bad prior to doing the heads. I'll need to dig into that at some point soon.
I also found that the outer tube seal is dislodged on the driver side and just riding on the axle shaft. Need to address that as well too.
Found out my oil leak was a cracked oil filter cap causing it to burp out. New cap = no more oil leak.
Also, I found a cheap Edge Evo 15051 tuner that I just sent off to FICMrepair yesterday to hopefully convert into a Gryphon tuner so I can have the ability to tune my FICM but also to change the FICM tune whenever I please. Pretty stoked on being able to do that!
How did I miss this thread? Awesome truck and great work to date, look forward to following along…
I’m considering selling my 80-series for one of these. My daughter has 4 boys and I’d love to make an adventure wagon to explore with them. The 80 just doesn’t have the space for them and all the stuff.
I had a great experience with my 6.“blow”. It had a full bullet-proof kit when I bought it but I did lose a HPOP once and that stung a little but overall loved that truck.
I got my FICM tuner back from FICMRepair and they successfully converted the Edge tuner I found for cheap into a Gryphon tuner. I've been playing with the different FICM tunes and think the Atlas 80 is where I'll stay until I get an ECM tune in which case I'll drop down to the Atlas 40. Damn these FICM tunes really wake up the truck. Driveability is so much better and the ole girl scoots much better now. I'm glad I was able to track down a tuner to have so I can swap tunes as I see fit in the future. Debating preemptively doing the upgraded Direct and EPC solenoids in my 5R110 to help the trans stay happy with the extra power.
I also sent off my overhead trip computer to someone from eBay to be rebuilt as it was getting very dim and the compass was in constant calibration mode. All fixed now for the low price of $24.
Got my big boy alternator installed today. Replaced the stock 110A alternator with the USA Diesel 240A with the deluxe wiring kit from FICMRepair. Getting 14.5V at idle now and shouldn't have any issues with glow plug draw now or damaging my FICM or killing batteries in the winter or short drives.
My wife’s GX was aging and it was time to replace it as a daily. She wanted the Expedition Max for all the room. Drove down to Pawley’s Island Saturday and picked up a used ‘24 with 25k miles. Hoping this thing is trouble-free but it’s no where near as cool as the old Excursions. Good luck with the project, look forward to following along.
Quick pic from dinner after leaving the dealership
Fixed my front end clunk today by changing out the completely shot sway bar links and bushings.
Moog end links and poly bushings. I also have ID Speed's custom Sport and EcoTorque tunes loaded on my new Edge Insight + waiting to get flashed onto the truck. I'm showing uncharacteristic refrain in not loading them until my EGT probe arrives so I can keep an eye on my EGTs to avoid melting exhaust valves. I expect it to arrive in the next few weeks as it was a freebie when you purchased an Edge tuner before end of August, which I did. The tunes should provide a nice kick in the pants once loaded.
In other news, as of a couple weeks ago, I've officially put 20k miles on this truck since I bought it at the end of March last year.
