UPDATE: Since I am now stocking the same bulbs but with a different socket to fit the 80s Series, I thought I would go ahead and update this post.
5W CREE Q5 High Power reverse lights. This is a single LED, high powered bulb that is an order of magnitude brighter than the OEM halogen type. Makes backing up on the trail (or those long curvy driveways) 10X easier. These mount in the factory locations with no additional modifications necessary.
100 Series
5 Watt Q5
Socket 7440/7443
330 Lumen
30-50K hr. lifespan
80 Series
5 Watt Q5
Socket 1156
330 Lumen
30-50K hr. lifespan
60 Series
5 Watt Q5
Socket 1156
330 Lumen
30-50K hr. lifespan
$40 for a pair (2 bulbs) shipped to your door (in the US). I will consider shipping outside of the country on a case by case basis.
100 Series
80 Series
Note: Pictures do not do justice the the difference in light output. I posted comparison pictures because I knew they would be requested.
5W Q5 CREE (Left), OEM (right) - Note: This is a picture of a 100 Series
Install notes:
*Make sure to have someone with you who can put the vehicle in reverse as you test fit the bulbs as they are polarity sensitive.
100 Series
5 Watt Q5
Socket 7440/7443
330 Lumen
30-50K hr. lifespan
80 Series
5 Watt Q5
Socket 1156
330 Lumen
30-50K hr. lifespan
60 Series
5 Watt Q5
Socket 1156
330 Lumen
30-50K hr. lifespan
100 Series
80 Series
Install notes:
