Alright, well I made great progress with my other projects yesterday and if my timing is fully mechanical the truck should be ready to test drive a bit today. Anything I should be listening out for or paying attention to in regards to the timing functioning correctly? Obviously precombustion knock will be a major red flag, but anything more subtle? Will retarded timing have any obvious symptoms or just poor performance?
When too far advanced, it will make a lot of knocking and even white smoke if it's really bad. Power will be down obviously.
To far retarded it be very quiet almost like a gas engine. Harder to start if the base timing is retarded. And power down again.
So if it where me, I'd just check that as the rpms increase, the sound stays fairly consistent and does not get too quiet. Much like how your 2LT engine was.
With stock 5L fuel setting your power will be the same or less than your old 2LT. So don't expect lots of power until you've tuned it.
Does your injection pump have a altitude compensator? Are you applying boost to it? I'm not sure how the compensator needs to be adjusted when going from an altitude to boost compensator, but worth looking it up. The position of the fuel pin, and spring resistance etc. is critical to your power curve.
