555 Drag Link End Issue
Ocho77
Alpena, MI
Website
www.op-art.guru
Fellow Mudders,
I've somehow managed to get myself in a predicament.
Replacing the Tie Rod, Drag Link and all 4 ends, as well as steering stabilizer. I used the 555 ends from Cruiser Outfitters.
On the passenger side, the bolt for the drag link end will not fit through the hole in the arm. The threaded part goes through, but the smooth part at the bottom of the bolt will not fit through. In my ingenuity (or stupidity), I put the castle nut on thinking I would just pull it through. Well, I'm afraid I am way over-torquing the bolt on the drag link end by doing this. So, I took the castle nut off, but the drag link end is now stuck and will not come out. For obvious reasons, I'm afraid to beat on it with a BFH to get it out.
Will it weaken that bold substantially if I use the castle nut to pull it through, or do I need to get it out?
Open to suggestions.
Cheers,
Jonathan
Fellow Mudders,
Cheers,
Jonathan
Get pics. Did it mostly seat when you cranked on it?
Well, I think it's user error. In my haste, I put the drag link end on the bottom with the bolt pointing up...I believe on the passenger side, the drag link end sits on top of the arm.
Now I have to figure out how to get it out without destroying the bolt.
@nukegoat thanks...and to answer your question, yes it did...with a lot of torque...approximately 80 lbs.
Yes it goes on the top. Lol. Put nut on the threads and hit with hammer until it ejects out the bottom.
Probably too late here but, put the nut on upside down before wacking it with a hammer.
Better yet, use a different, softer nut from the hardware store so you don't damage the good nut with the hammer
Make sure you thread the nut on there about 5 turns before you start whacking it with a hammer also. If you don't get enough thread engagement you will make the nut skip threads from hammering and you'll be buying some new TREs.
