54mm Socket
Calgary, Alberta - Canada
Would like to buy one to do my bearing this weekend. I was wondering how deep the 54 mm socket should be to do the job? I have found one locally but it doesn't seem to be deep enough (~ 37mm deep), will that be O.K. or should I hunt for a deeper one? Does Sears carry anything like that in their Craftsman line? Where did you buy yours?
I hate to go back shopping while in the middle of the job so I would like to get the right tools beforehand..
Cheers,
The two 54mm locknuts are not deep at all. I can't say it will work for sure but I'm almost sure it will. 37mm deep sounds fine.
It just needs to clear that bit of threaded spindle.
x2. The locknuts are not deep at all, any standard depth socket should work.
Thanks guys.. that makes me feel more confident,
I was just going by the picture in the FSM and the one from this thread
https://forum.ih8mud.com/80-series-tech/292265-replacing-front-rotors-brake-pads.html
I will just make do with what I bought, hope it'll be alright..
Cheers,
Cancruiser
I found that a 'wheel bearing' socket is easier than a conventional one for that job (that pic you posted looks like an impact 2 1/8'') ....like an OTC 1950M which is 54mm.
Just get the 1/2'' to 3/4'' adapter as that socket has the bigger drive
Napa should have one or be able to get it in short order. FWIW.
Cheers,
Gord
