5' castor correction bushings?
They are poly, same idea as OME but much more correction. I have traded emails with the seller, who states that he has used these bushings in OZ without issues on some hardcore stuff.
I think they are worth a shot vs. caster plates if you need that much correction. Question is how much lift you have and whether the bushings align properly for a CV shaft or continued usage of the stock shaft.
Nay
I am piecing together a j spring lift. rear springs on the way. I have 1' spacers for rear. I need some front springs. I just finished welding up some 2" spacers to bolt in front between the bump stop and spring hanger (as others have done). I need front j-springs. I made some shock adapters so I can use easier to find (ie cheaper) shocks. just tossed the oe mufler and welded in a glass pack up high. am working on a skid. The castor issue hasn't been solved but I may try these bushings-they also make a 4' correction bushing. I doubt they will hold with so little rubber on the short side. I may just make some correction plates
dusty
They arent 5 deg they are 3.5 degree.
I will have a word with hobzee, [I know him]
Plates are the way to go.
And, yes Ive tried them, I have 10" stroke shocks on the front, using all 10" of stoke, and I got 13000km out of them.
