here you are. Adapter plates and variious parts for retaining the stock 3 speed.
http://www.advanceadapters.com/catalog/064.html
Diesel Dude said:The 350 chevy is easy to put in and a 383 stroker kit doesnt cost that much so if you are looking for performance that might be an option that is easily installed
LoneStarFJ said:If the stock motor ever dies ( I doubt it ). The 5.0 swap was exactly what I was thinking. My reason for the change out are a bit different though..........
I personally think that the 5.0 with flowmasters is the coolest sounding setup !!!!
Travis
89s rule said:I have owned 3 5.0 Mustangs so I may be a little biased. But obviously Diesel Dude doesnt know much about Fords.
They make stroker kits for them as well 331, 347 are most popular for the 302 (5.0) and 393 is most popular for the 351. Power per cubic inch is always higher with a ford, and according to everyone here its also a lighter engine. And the dist. is in the right spot
Aftermarket for 5.0 is huge, more than you would ever want to spend on an engine in a cruiser.
Main thing I love about cruisers and other 4x4's is that you can lfor the most part, leave the engine alone. And if you do want to go V8 then you dont have to drop tons of cash $$ on performance parts. (Like over $2K cylinder heads, etc!)
If you want info on ford stuff check out www.corral.net its a Mustang boards but tons and tons of info on everything including engines.
LoneStarFJ said:I personally think that the 5.0 with flowmasters is the coolest sounding setup !!!!
