4WD not working
I think the spring looking thingy is from the shaft seal that goes in that main hole. The piece of metal could be from the birf itself, the bell part.
Knuckle itself looks ok to me. Change out that axle seal in there and make sure there aren't any other metal parts floating around inside the axle housing and then clean it out. Looks like the entire axle was missing? Hopefully the diff is ok too; I would suspect it probably is..
wait, how was this thing holding any differential oil? lol
Once i started to understand what was wrong and that it could be damaging the vehicle i stopped driving it, because it was not holding gear oil. There was paper towels in the spindle and a towel stuffed in the bell.
Hopefully other components are ok. I now think the broken pieces were from the old birfield.
I'm going to dissasemble the other side tomorrow and rebuild both knuckles with bearings.
going through the kit and not being in front of the vehicle. This larger ring would be the axle seal, but I'm not sure what the smaller ring is? If this somehow goes in the axle shaft how do you remove it/install it?
Little one is the axle seal, big one is the grease seal.
Although, your axle seal looks different than what I remember...
Photo by 93chewbacca
That's a Marlin inner axle seal. They have a bad reputation on Mud for leaking after a few thousand miles, although my own experience with them was OK. You might want to use Toyota inner axle seals if you are doing more than a temporary repair.
Look at this on eBay Land Cruiser FZJ 80, LX 450 ABS Ft Axle Long Side #5090 | eBay
I bought this axle birfield and installed and rebuilt the knuckle.. yayy! Excecpt when i got to pulling the birfield out from the hub cap thing with a screw to put the c clip in. The birfield moved out very little not exposing the snap ring groove. It would move in about an inch and a half.
Is it possible i purchased a short birfield? What if i grinded down the cap and reshaped the teeth if need be?
For an early birf and late plate. Get a fender washer about the size of the plate edge where the cap goes, install it with a short M8x1.25 bolt, hammer the cap on, done.
Did this and the truck runs great and smooth. Installed a replacement birfield and axle and rebuilt the knuckle. Played around a little with it today center and front locked. Not the rear for some reason.
Thanks everyone for your help and encouragement. Success !
