I am having a little trubble removing the center transfer case without pulling out the upper shaft bearing. I might have pulled the upper shaft bearing out a bit to far, is this a problem? 4WD part time conversion.
If that's the big, round thing near the top, mine slid out a bit and prevented me from putting the rear cover back on. I tapped it back in with a plastic hammer. I couldn't push it in by hand from such an awkward position.
Ok, I will try that and I was thinking of removing the small snap ring that holds the roller "not sure if that is what it is called" in place. pictures will be arriving soon.
That little f---er top left. I will head back out there and give it another shot. In the last two months I have done a lot to my cruiser. As soon as I finish this project I will up date all of what I have done with pictures.
So the problem is that you can't remove the cover, correct?
If I remember correctly, you remove the small cover over the round red thing, remove the large, outer snap ring, then you can pry the case/cover off. You shouldn't remove the smaller retaining ring.
The red thing will want to slide out with the case. Give the shaft a few moderate taps with a plastic hammer to push it back in, then go back to prying the case/cover off.
Success, Isn't she pretty. Thank you guys for your help and encouragement. A brass punch a few taps and a helping hand from the Land Cruiser Gods, hey the weather is fine come on in. The viscous housing, should that be left as is or should I remove that little 1/2 round protector plate thing.
OK, I will just leave it. All the mating surfaces have been cleaned. Now I have to wait till Monday and head to a shop that can press the old bearing off and press it on to the new spool. Did u reuse your old bearing, mine seams a little sloppy.
I ordered a new Timken bearing. It was actually one of the most annoying parts of the whole process, since it took forever to find the correct bearing number, plus I had to make a press tool. Yeesh. Had I known, I would have just bought the Lokka kit that includes a new bearing already pressed on ($50 more or so).
From my notes, the bearing is Toyota p/n 90366-60008, Koyo STA6095, or Timken 32012X. $27.79 from RockAuto for the Timken.
Great, I will order a new bearing. Don't want to go in there again. Thanks for your help and maybe tomorrow I will start posting all that I have done in the past 2 months.
Pressing it on, with the indicated Loctite for bearings applied:
The press tool was just a chunk of flat stock with the ends rounded off. It's probably not ideal, but I don't have a lathe to turn down press tools, and I don't have enough pipe and tubing sizes laying around...
One of the biggest pains I had was trying to get that top, left bolt torqued properly. If loosening the cross-member bolts will drop the transfer case down a bit, it would be well worth doing to get easier access.
