4speed transfercase linkage
Woodstock,GA
Need help trying to figure out why my shift lever boot doesn't side all the way up to the transfer direct assembly shaft.
Pic from elsewhere on mud.
Can’t see much in pic, but the boot goes around both the case and the round shaft to keep crap out of the case. The junction between the arm and the shaft is just lubed but open.
Thanks. That's funny because I have downloaded several photos on transfercase with that shifter linkage setup and that photo was one of them before I ran into the problem. I believe I found the reason it's not butting up closer to the shaft. I think the shift linkage is bent some where the boot butts up to the shaft. I had another shift linkage and it set in closer to the shaft.
If it’s not close enough in it could be the washer on the stud or the shoulder is too thick.
Could be bent also... or a mix and match of parts.
BTW, if you remove or notch the ‘plate’ it’ll allow 2wd low. Particularly helpful for 2wd - 4wd shifts on the fly in low range.
