The RPV resides in the master cylinder right behind the cone that the tube seal on inside of the outlet port. Symptoms of one missing or malfunctioning are usually a low pedal or a pedal that requires more than one pump to get full braking.
From Summit's page details:
"...With drum brakes, 10 lb. valves are used to compensate for return spring tension in the drums."
but sounds like you still have air in the system or the adjuster assembly/automatic adjust level arms are malfunctioning. If the rear brake system is not operating as designed then I could see the adjusters backing in from the spring pressure and thus backing the shoes off the drums.
