4link 5.0 fj40
i have had my project for 4 year. hope it runs by the end of the year. long story short got a house and saved for some better parts here some pic
I saw you post that on FleaBay - was sooooo tempted to bid as it was a slamming deal. Good to see you kept it - and hopefully that new Atlast too.
have been working on my fj . went to pull a part and got right side wheel hub and nut. ford f150 shifter boot and a starter. also got some ford shock towers for $50 dollars that place is great. i did get a new clutch master cyl and made a slave cyl mount still need the line. got a good start on the tranny tunnel
Love the trans tunnel my man!
Great start!
i will get more pic up off over the weekend of some more work. and 74fj40 it is a x3 switch good eye thanks for looking
some pics at ride height with 35 inch tire. also rear 4 link welded up . ran out of gas for the welder. need to get wheels and tires that fit so i will know how much room i have for coil spring and mount.
did not get it to run last year. i did get driver side header painless wiring for the motor and body. over the weekend pick up some h2 wheels and tires. need fuel tank and pump. then to some body work
24 1/2 to the bottom of the frame rail. Hope it sag with the rest of the parts that are not on it
got a fuel tank order fuel pump, filter two 12inch travel shocks and some body spray. have two raise the floor in the rear 2 1/2 tow clear gas tank from the rear end and to fit 12 travel shocks. trying two keep it flat and closed off is i can need rear seat for my little:princess: on the way
got a 15 gallon fuel tank. pic of tank and pvc shock that is 3 inch two long. hope the fill tube runes along the front of the rear seat.
my first exhaust job. need to to get the driver side pipe to end in the other pipe. need to get a muffler and run the rest of the way out the back. thanks to metal tech for having a sale. my cage kit should be here in a week or so.some pic of my pipes think it will work? got my road racing motorcycle up for sale . that money will be used for the other parts i need to make it run and drive i hope!
Used drag racing drive shaft hoops. for shock mounts in the rear also got so pipe for gas tank mount that should be done soon. Thinking what going to be the best way to close off the big hole in my floor
work has be slow . my metal tech cage show up so i had some time to work on the fj. got 4 more bars to fit to the cage and all of the frame tie in bars to do. hope to have it done by the end of the week. got to go dyno on in a day to tune a sti hope it makes 400hp to the wheels
