40s, 60s, 80s parts
Saratoga Springs, UT
Found some more parts so I'm adding those, also updated some prices.
80 series rear air defelctor brackets, yes I found them, $10 for the pair
80 series '94 stock front springs $15 pr
80 series '94 stock rear springs $15 pr
60 series front or rear axle housing $25 ea pictured
60 series front sway bar $20, includes frame mounts but not axle mounts, pictured
40 series ambulance door grab handle for '75 to 8/76 $10 pictured
40 series hard top corner brackets above ambulance doors $10 pr pictured
40/45 series stock steering arms, small bolt pattern. $15 pr
40/45 series 1982 windshield frame, no glass or hardware, non-usa threaded holes along the top for soft top channel (does not include soft top channel) $100 pictured
40/45 series 1976 muffler heat shield, attaches at the area of the tub above the muffler $10
40/45 series 3spd transfer case (picked this up at a junk yard from a 72 I believe, not 100% it could be 4spd), empty case only, $20 pictured new price
40/45 metal seat back, out of an '79 or '80 40, $15 pictured
40/45 '82 mirrors, plastic is cracked, chipped, glass is good, arms have some chips and surface rust $15 pr
All prices do not include shipping. I am near washington DC, in Virgina, zip 20155.
Dibs on the gas can carrier, can you post pics of it? If its the one I'm looking for consider it sold.
This one isn't mine, but this is what it looks like, has all the parts, including the rubber deal at the bottom that eliminates vibrations.
Does the gas can carrier bolt to the lugs on the spare tire?
2nd in line for the gas can carrier
Yeah, so you put the spare on, then you put the gas can carrier on, then the lugs hold both in place. I used it a couple times and let a friend borrow it once. Works fine, I just don't need it anymore.
ANY fj60 rear springs?
If you don't like the price make an offer, if you need a pic of something, let me know. I need this stuff gone. Thanks.
more WS frame pics, Kief, please give me a decsion in the next couple days, thanks.
The ws frame is dented a little near one of the hinges, it has bondo right in the center on the front (but doens't feel dented from the back, not sure why it was skimmed with bondo). Where the hard top over door pieces bolt to the w/s frame it's dented a bit as well (like it was pushed on when the top was on it. It's solid and not rusty though.
first pic, bondo in center, 2nd pic dented near hinge, 3rd pic, backside of ws frame where the bondo is, not sure why it was bondod.
