40 to 45 transformations....
Here's some pics of too tall's w/ 98" wheelbase SOA w/ 2.5"? lift springs - sick...
well.. this is my truck lovingly nicknamed Fj-rankenstein...
it started life as a 1977fj40..what has been done is:
-frame streched 14 inches
-I took the worst out of 3 fj45 spare boxes and bobbed it to 4 feet long
-original fj45 hardtop( I have 3..)
-aqualu fj45tub mounted on custom body mounts
-spring over with 60 series spring front and back with shackle reversal and 60 series axles
-saginaw power steering
-35 inch boggers
-seats out of a 1993 toyota pickup
-onboard air
-4x4labs steering with gm 1 ton ends
-warn winch
-70 series front signals
-4 wheel disc brakes
-final wheelbase of aboot 106 inches
I have about 1.5 inches between the cab and box so it doesnt interfere when flexing..
Hope this helps!!!
-35 inch boggers
-onboard air
-warn winch
Hope this helps!!![/QUOTE
That is so cool, I think I'm going to start another project rig.
nice pics y'all,
fjmaryshelley and redrustbucket, thanks for postin that stuff up...
so redrust, are you not flippin the springs or anything? or is that just up next...
question on extending the frame....where did y'all do it?
i saw that gifu did it towards the rear, and 6lugs did it right after the tcase...what abt you fjrankenstein?
malphrus
Fawkers:flipoff2: - just what I need, another project to think about.
Nice work guys, you might want to check Pirate for a few more photochops of the mustard ext. cab too. I remember a pretty cool thread over there about this topic.
if only I didn't hate bodywork so much...
72cruiser said:
nice pics y'all,
malphrus
Thanks for all the positive feedback guys!!
I ended up stretching the frame on mine right behind the front tranny crossmember....I got identical "c" channel made up and put in 14 inches that way.. I cut my crossmember like "/" instead of "|" to get more surface area to weld to hopefully make it stronger... I than bent up 2 more c channels... one to fit inside the outside one but slightly staggered and than one huge one made of 1/4 inch material to go over top of the outside framerail that goes the entire length of the tranny cross member right to just past the back of the 45 cab...mabey a bit overkill but that just tends to be the way i end up building things....its actually quite amazing how I notice how the frame really firmed up.... weather or not that really affects things I dont know but the truck feels really solid...
Oh and as well.... measure measure measure!!!!! I cannot stress how important it is to measure!!!... quite important if you actually plan on daily driving your rig like I do.... I am sure if you are building this for straight trail use than mabey its not quite as important but to each their own!!!
good luck!!!!
gotta do something with the wheelbase, either flipped 60 springs SOA in rear or somekind of coil set up... I'd rather not stretch the frame but who knows... def. switching out my rear springs tho, I've got plenty of other junk to mess with right now.
