40-60-70 DIY Bumper Kits
Would you buy a DIY Bumper Kit
  • 40 series
    Votes: 52 44.4%
  • 60 series
    Votes: 52 44.4%
  • 70 series
    Votes: 20 17.1%
  • NOT INTERESTED/ Prefer a fully built bumper
    Votes: 4 3.4%
  • Total voters
    117
  • Poll closed .
Aha, pictures say it all. Thank you sir. Just when you get a chance. Need a few measurements for where to mount the tire upright and the ladder.
R,
Depends on where you want them and what size tire you run.... 35" tire ... run 18" from the spindle to center of tire carrier upright... But your call. Ladder is up to you.
J
Hey J did you use a piece of 2" angle for a stop for the two swing outs? What do these new laser cut pieces look like?
There should have been a couple of 1/2" diameter rod pieces about 7/8" long. Weld these where the spring pin will hit them and stop the arm where you want it to stop.
I guess I should have been more specific. On the main shell, where the two gates meet in the middle, is this a piece of 2" angle that stops the gated where you latch them.
Thanks J, it's coming along nicely.
And yes the upper hatch is not closed all the way. LOL
All,
With the expansion of new products and running out of room in the shop, I will no longer offer these after March 1st.
Here are the DIY kits I have and will offer special pricing on until Feb 29th at midnight. I can add swing arm accessories for extra cost let me know.
DIY - Bare metal
2- 60 rear dual swing base kit---(shell, crossmembers, spindles, recovery points, receiver frame mounts) $575.00
1- 40 rear dual swing base kit---(shell, crossmembers, spindles, recovery points, receiver frame mounts) $500.00
1- 70 rear dual swing base kit---(shell, crossmembers, spindles, recovery points, receiver frame mounts) $500.00
2- 40 front 8274 with bullbar ---(shell, mounting plate, recovery points, bullbar hoop) $175.00
After Feb 29th they are gone folks. I will tear the kits down and put them back into the "GEN POP" stock if you will.
Thanks for all the orders and support guys,
Jason
Updated list
1- 60 rear dual swing base kit---(shell, crossmembers, spindles, recovery points, receiver frame mounts) $575.00
Jason
Had a couple of the frame mounts made out of 3/8" material. If you were gonna sale these to someone, what would you charge?
