4"SJ+33x12.5+2.5"BS+Manual Steering
Cincinnati
Does this combo just lead to some super crappy steering for wheeling? I guess I could add a locker and make it worse. I'm thinking about going to 2.5" BS wheels on my rig, any problems doing this with a 4"SJ setup?
The width of the tires will be the biggest factor. On the road it will be ok, but offroad slow speeds it will be challenging. It is doable if you have strong arms (if not you will) though.
I think wheeling without power steering sucks. BTDT One of the first things I added was minitruck PS to my 40. While it is not as effortless as saginaw I think it works great offroad with a autolocker and 33s. I can't imagine if you had an auto locker without powersteering.
i ran 35s on 10" rims with manual steering. it was ok. mudders will be easier to turn than all terrians(less rubber on the road).
Sure, it can be done, but it isn't pleasant. I did Hells Revenge with 35x12.50s on 10" rims. FORGET THAT. When I was done I felt like I just did the Baja 1000 on a bike with a flat front tire. Talk about arm pump. I wasn't the same for days. First thing I did when I got a chance was a 3 1/2" Saginaw. The single most important mod for a Cruiser is power steering IMHO.
Wimps
:flipoff2:
Anything can be done. It just depends on if you want to work at it or not.
Sag PS is cheap and VERY nice ;)
I'm wheelin right now with that setup, except I am running stock BS. I'm not sure how less BS would affect the difficulty of steering.
8" rims are a must, the more aggressive the tire, the easier it will steer on road (less tread contact surface).
I do have strong arms and it is not a problem, there have been some situations I wished I had PS, which is why there is a minitruck box sitting in my garage right now.
Less BS increases your scrub radius. Making the turn harder
