4 inch lift question
Badger, Minnesota
i am still up in the air over going with 4 inch or 2 1/2 inch. from what i understand you put a 2 1/2 inch in a go. and with the 4 inch you gotta lengthen the brake cable's and possibly shim up the driveshaft if not put a new one in. is there anything extra assotiated with putting the 4 inch in? also with you guys that have the 2 1/2 or 4 inch in did you make the right decision for yourself and it would be nice to hear why you did or didn't make the right choice. as of right now i am leaning towards 31 inch boggers for tires. i plan on using mine for trail and offroad use. the price difference is only about 20 dollars between the rough country 2 1/2 and 4 inch.
I did the 4 inch and love it. Looks good, great ground clearance and aritculation. Can shove my tires all the way into the wheel well. Only issue I seem to have is driveshaft vibration at about 40 to 60 MPH. Driveshaft angles should be the same, or close to it, coming out of the tranfer and into the axle. Mine is not. Currently looking at having a c/v shaft made. Lifting your rig is all in what you plan to do with it. Good luck!!
I'ld go for the 4". The following reasons come to mind:
1. 31" boggers are good but tend to run wider than most other choices due to the aggressive sidewall treads and overall flat tread design. Boggers side biters tend to do allot of body damage when they contact the sheet metal
2. If you continue to wheel in the mud? then 33's or 35's are likely in your future: better third member clearance, better contact patch, etc.
3. Better to do it once as money seems to be an issue in your post.
FYI
I am running 3 1/2" suspension and 3" body lift with 35/14.5x15 Maddogs. They tend to run wide and tall. Have minor rub issues out back. Had to dolly over the wheel well standing seem to alleviate the tire damage. You may run into a similar issue as well
Best of luck
Do the 4" and do it once. Several friends did the 2.5" and later went 4". I did the 4" and haven't had any problems. Unless you go with longer shackles you shouldn't have to use the caster correction shims. You will have to buy longer brake lines though. They probably need replacing anyway. That's my .02. Good luck.
Later,
I went with the 4 inch lift. I'm glad I did. I wouldn't want to go any shorter. I have slightly longer shackles, and run 33s with no problems whatsoever. As far as the brake lines, that really isn't a big deal. I went with the braided SS. To me, that was an upgrade that was well worth it. The old, cracked, 36 year old brake hoses were due for replacement. The shims you may or may not need. But, they really aren't that expensive, and you will be "in there" anyway while installing your new springs. No biggie. I shimmed the front axle for castor correction, but I didn't shim the rear. I do have a slight vibration at about 50-53 MPH. It really isn't that bad.
If I had it to do over again, I would go with a SOA. I would save up and do it right the first time. It is more expensive, but I think you get a better end product. Personally, I'm getting kind of tired of the rough ride of the 4" lift. It isn't horrible, but SOAs are much smoother riding if done right. You just can't make a smooth riding spring with that much arch. Besides that, you are saying that you are primarily going to use your rig for trail and offroad use. Go SOA and don't look back!
:cheers:
4 inch
I have a 4 inch HFS, to me the 4 inch just looks right. Yeah you need to buy a set of extended brake lines but they are available form several vendors or even your local auto parts.
Some people say they need shims to correct driveline vibration but HFS advised going without first then adding if needed
all in all the 4 inch was an easy swap I took 2 weekends but that includes all the sanding down to metal and cleaning and painting before the actual lift was done.
I like the 4 inch with 33 x 10.5 it looks good without looking extremely modified, just makes it look right!
thanks for all the honest answers guys. i made up my mind that i will be going with a 4 inch now. and when it comes to rough ride nothing is worse then what i have now. sacked out springs with blowen out shocks with a total of maybe 1 inch of travel. i would really like to go with 32 inch tires but they don't make 32 inch boggers. so i was also thinking of the 32 inch super swamper tsl's. that is still all up in the air. one thing that isn't up in the air anymore is how much lift i am going with. i am also gonna be buying all the poly bushings as well.
