cardinal fang said:So, you relocate the sensors off the engine and onto a firewall? I think painless does that with their harness for the TBI. I would like to get all that 'stuff' off the TBI in my 55. I will look into that, after Rubithon.
Scott R said:Who is the vendor on the fuel pump? I am trying to find the best 14psi TBI pump I can.
Gumby said:Butch,
Is that MAP sensor mounted with the vac hose coming out of the top? A GM tech at the Warren Tech Center told me they must be mounted with the vacuum hose down. The condesation will build up on the vacuum sensing membrane and frezze overnight, damaging the membrane. The hose should be mounted so that condensation will run away from the MAP.
Could be BS, but why chance it?
I just re-read and it looks like you said they are mounted to the underside of the glove box. Does that mean the pic is upside down and the vac hose is right?
Thanks, the V8 would work in the same location we are using here, be a dang easy swap in fact....the LH manifold would cause problems moved any farther back, besides the rear driveshaft is perfect here...flexplate the same as long as we are talking post '88 FI motors2manycruisers said:This is a great thread, great work Butch. I will be doing a 2003 vortec 4.3 into my '65 fj-45 one of these days, so lots of great info here.
thanks,
David
seventysixforty said:hey Butch,
Dustin mentioned that he had water leak into his ECM. I never had any leakage into the glove box on my '75, so what are your thoughts?
-Lance
