3FE York Compressor mount
cruisermatt
Un-manufacturable
Supporting Vendor
Winter Park, Florida
Website
www.cruisermatts.com
Has anyone mounted a York compressor in place of the smog pump on the 3FE? I want to have one in addition to the stock AC compressor. Has anyone done this successfully?
Nevermind, I just searched and found a boatload of info.
Haha. Yes. Look up @jonheld. He did this a while ago. I'm planning to do it soon, hopefully.
Cruisermat:
If you find a good thread about it, post a link here
Thansk
This might be one of my favorite mods. I use it a lot for airing up bike tires and air tools. It's great not worrying about finding a gas station to air up after the trails..or spending 45 minutes using a 12v compressor to blow them up.
I copied from my build thread.
"Mounting it is the tricky part. My dad desmogged the truck awhile ago, and the compressor went right where the smog pump was. A custom bracket had to be made that held the side of the compressor where it wasn't rubbing on anything. At first, we thought that was fine. At 950 rpms, it would vibrate really loudly. It was only at that RPM. It annoyed us enough that we came up with another small mount was made to secure it to the alternator mount. The air comes in through a hose that is connected to the air filter. It gets compressed, and is then fed to a 6:1 air manifold with a 175 PSI relief valve, gauge, pressure switch, and then goes to a water/oil removing coalescent filter and a one-way check valve. From there, it T's out to the back of the vehicle where it runs through the frame and to a tank, and front of the vehicle where an air outlet resides in the bumper, and then to the air horns below. All fittings are 1/4" brass push connect utilizing semi trailer air lines. I also have a pressure gauge installed in the cab as well as an air compressor switch to turn it on/off."
