3FE AFM to MAF conversion
Some time back I posted a thread about my in car PC, LC1 wideband O2 and upcoming AFM to MAF conversion (https://forum.ih8mud.com/60-series-wagons/421776-lc-1-wideband-o2-pc-install.html). I'm using a Split Second PSC1-005 with the inverted 5-0v signal to match the stock AFM signal (http://www.splitsec.com/technotes/AFM_to_MAF_Conversion.pdf). I finally got some more time to work on this the past couple of weekends so I'm starting a thread.
Progress may be slow but the truck starts, idles and free revs light throttle up to 2000rpm. I tuned without the stock O2s connected, aiming for 12.5-13.5 (better to run a bit rich and have the ECU use the O2 feedback to trim the fuel back than to run lean and have the ECU have to add fuel). I then plugged the stock O2s back in and let the ECU learn a little. Wideband indicates that with very little learning the ECU has trimmed nicely and is running well. I haven't driven it yet (see next) but so far this is going well. I've already managed to smooth out a rich spot with the stock AFM where for some reason I'd run 12-13:1 (rich) between 1100-1400rpm. Immediately above and below this range was always in the 14:1 range.
I'm having a couple of problems that I still need to work out. First, I've got a 31 code. The ECU doesn't like something with the VS or VC signal (AFM signal and power respectively), but it is probably a signal out of range issue, maybe at initial start up. It doesn't seem to impact anything, but I'll be chasing it down nonetheless. The second problem is that the PSC1-005 has an aux driver to energize the fuel pump. The stock AFM will only allow the fuel pump to run if air is actually flow (this is a safety measure). My PSC1-005's driver doesn't appear to be working (I've confirmed that the stock +12 that I'm feeding it from the stock AFM wiring is under it's 200mA limit - it's ~100mA). I'll need to call Split Second on Tuesday to see what is going on. I've simply jumped this for the time being.
Otherwise this is going very well so far. The goal is a little better mid range and higher power (2000rpm+) and to keep the ECU from going into open loop (and overly rich) as easily at 2500+rpms.
Not very exciting, but here are some pics:
Those are so similar, how will you ever choose?
